96 maxima and trunk release
Maximus96
Member - Posts: 17
Posted: July 28, 2005 at 8:22 PM / IP Logged
i found out the trunk trigger is -12 for the maxima from the digrams provided on this site. I can't remember if the Viper 600ESP outputs 12+ or 12- on the 3rd channel. if its 12+, how do i wire a relay to send a 12- signal? if its 12- from channel 3, do i still need a relay? if so how would i wire that?
thanks
Powermyster
Silver - Posts: 962
Posted: July 29, 2005 at 5:16 AM / IP Logged
I'm sure its a (-) output.
86  -  alarm output
85  - constant 12V
30  -  solid Chassis Ground
87 - (-) to solenoid
thepencil
Gold - Posts: 1,526
Posted: July 29, 2005 at 8:34 AM / IP Logged
Trunk/Hatch Release purple / YELLOW    -   low drivers kick
NISSAN, MAXIMA, 1996, Trunk/Hatch Release
Must use a relay to interface with this circuit.
WHITE/ Blue is a low current 200 mA negative output wire on the unit. Follow Powermyster direction for the relay connection and you are all set.
Be careful whose advice you buy, but be patient with those who supply it.96 maxima and trunk release -- posted image.
Maximus96
Member - Posts: 17
Posted: July 29, 2005 at 12:26 PM / IP Logged
sweet. thanks so much
Thursday, August 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
