Stater kill (-) output
goofy1953
Member - Posts: 10
Posted: December 01, 2002 at 7:29 PM / IP Logged
Hi All,
 I'm newbie of this Web site. i try to Install the remote,starter for my 1994 Toyota corolla. In the Installation guide show me " Orange : connect to a 30 Amp. Relay for starter kill (-) output." My question is:
 1/ How to make starter kill? what part do I need to buy?
 2/ I looked in diagram it show need diode 1 Amp. between 86 - 85 lead. What the voltage need? I checked at RShack have several voltage 50V.100V,..... What  Voltage I need for diode?
3/ Could anyone show me wiring diagram  Instruction for Stater kill .
I have some knowledge w/ basic car wiring and this is first time try to DIY.
Any input will be appreciated.
Platinum - Posts: 12,488
Posted: December 01, 2002 at 9:58 PM / IP Logged
This link will answer all three of your questions. You can get pre-wired diodes relays at most electronic stores : https://www.the12volt.com/relays/page2.asp#sk1
goofy1953
Member - Posts: 10
Posted: December 03, 2002 at 12:06 AM / IP Logged
ThanksJeff  for your help ,
 I looked at basic starter kill , it show the lead 86 " to ign.12V (+)" where it connect to ? and I bough the relay 20/30 Amp, and ask for diode. The Tech told me I don't need the diode. Is this right ?
damon9
Member - Posts: 15
Posted: December 03, 2002 at 12:26 AM / IP Logged
yeah thats right some relays come with diodes, but make sure the 12 volt possitive is on 86...
damon
Posted: December 03, 2002 at 12:56 AM / IP Logged
Use the BLACK / YELLOW wire from the ignition harness for the switched ignition wire for the relay.
goofy1953
Member - Posts: 10
Posted: December 05, 2002 at 12:15 PM / IP Logged
Thanks again Jeff,
 One more question: The lead 30 need to connect to starter wire from ign. switch Or have to connect to starter solenoid?
Posted: December 05, 2002 at 12:33 PM / IP Logged
30 goes to the starter solenoid side of the cut starter wire.
cva2000uk
Copper - Posts: 60
Posted: December 05, 2002 at 5:24 PM / IP Logged
sounds like he is gonna have fun.Stater kill (-) output -- posted image.
"you wont like me, when i get angry" .
goofy1953
Member - Posts: 10
Posted: December 06, 2002 at 6:51 AM / IP Logged
Hell yeah, I'm working in garage for city around 2000 cars,trucks and heavy equipment .Unfortunately no electrical in my job except for general wiring . Other mech. when talk to them they don't help much. The main thing is learning so I don't hesitate to ask. I know will get help in this great site.
Hat off to you Jeff . Stater kill (-) output -- posted image.
Posted: December 06, 2002 at 12:32 PM / IP Logged
No problem, don't work too hard.... not worth it Stater kill (-) output -- posted image.
