1999 Dodge Grand Caravan Code-alam 425
kcjba
Posted: September 10, 2005 at 6:22 AM / IP Logged
Hi all
Here are a couple easy questions.
1. Below is the wiring diagram for my door locks however when I test the resistors on the main lock switch in the drivers door they work fine. But when I connected the resistors to the WHITE/ dark green in the white connector under the dash only the unlock works. So where exactly is this other connection suppose to take place. A physical description of the location would be greatly appreciated.
Door LockWHITE/ Dark Green (-) BCM at Fuse Panel 1500 Ohm Resistor
Door UnlockWHITE/ Dark Green (-) White Connector B58 Connector 250 Ohm Resistor
2. To control the windows would I need a window control module(outside of building my own)?
mo12v
Posted: September 10, 2005 at 10:15 AM / IP Logged
You may need to use 2 Relays to supply stronger Ground.
Power LockWHITE/ D GREENBOTTOM OF JUNCTION BLOCK TWO
Power UnlockSINGLE WIRE SYSTEMCONNECTORS,ONE ON THE LEFT. ***
*** Single Wire Door Lock System, WHITE/ D GREEN Wire Requires Chassis Ground Thru A 1.5K Ohm Resistor To Lock And Chassis Ground Thru A 249 Ohm Resistor To Unlock.
Also:
Use a Window Roll-Up Module
Reversal Rest At Ground Power Window Circuit
MO
