remote start starter wires
ty
Copper - Posts: 137
Posted: September 14, 2005 at 3:03 AM / IP Logged
just a quick question, so when installing the 791xv remote start, the key side wire would be connected to my starter wire from ignition to fuse box right?  And starter side wire would be connected to the starter wire coming from fuse box and going to starter right?  Thanks.
mo12v
Posted: September 14, 2005 at 8:06 AM / IP Logged
Yes...............For the PURPLE & GREEN Wires
MO
iskidoo
Silver - Posts: 1,046
Posted: September 14, 2005 at 10:10 AM / IP Logged
The way your wording it worries me. Don't just connect one wire to one side of the fuse box and the other wire to the opposite side. Pick a spot on the starter wire and just cut it in 2.
Steve G
ty
Copper - Posts: 137
Posted: September 14, 2005 at 3:35 PM / IP Logged
alright so just make sure I put the green wire before the purple wire on the starter wire?
mo12v
Posted: September 14, 2005 at 3:43 PM / IP Logged
Usually U would cut the Starter Wire in half at a location like the Ignition switch Harness.
Ignition Switch side of cut wire goes to GREEN wire
Starter side of cut wire goes to PURPLE wire
The 791xv keeps the car from starting with the Ignition Switch when Alrm is Armed
MO
ty
Copper - Posts: 137
Posted: September 14, 2005 at 4:22 PM / IP Logged
that was the info I was looking for exactly, thanks mo12v, sorry it just kind of confused me what with 2 wires going to one and all.  Thanks all.
simpsongary
Posted: September 16, 2005 at 12:10 PM / IP Logged
I have an Artic Start (RT2WAS) I need the user guid. Thanks Gary
Gary
Friday, September 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
