windows go up when i lock the car
lowone01
Posted: October 03, 2005 at 5:57 PM / IP Logged
How can i have my windows go up when i lock the car from the key fob. i am using a factory key pad on a 2003 mazda protege 5
youngone
Silver - Posts: 269
Posted: October 03, 2005 at 8:22 PM / IP Logged
sounds like it is built into the car. is it suppesd to do that
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
tragik
Copper - Posts: 169
Posted: October 03, 2005 at 8:58 PM / IP Logged
If you can roll the windows up by turning the key in the door, then all you need is a pulse timer. DEI Makes one called the 555t i think. Set it up so that it sends a longer pulse than the one your keyless does to the lock cyclinder wire. You can do it with a relay and a capacitor too, but you'd probobly be better off with the timer.
Northstart.....or start it your damn self.
auex
Platinum - Posts: 5,041
Posted: October 03, 2005 at 9:10 PM / IP Logged
Buy an alarm and a window module.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
redpeppers
Silver - Posts: 483
Posted: October 03, 2005 at 11:49 PM / IP Logged
window mod is the smart's way 2 do it.....it has resistance dip switches that will keep u from messing up ur windows and window motors
Where theres is a wire there's a way.
