bad brain or remote?
hondaccord94
Member - Posts: 11
Posted: October 04, 2005 at 5:58 PM / IP Logged
Well ive been having some problems the past day or 2. some reason my remote will pick up my sisters alarm signal/code, adn disarm both our cars when its not even programed, it does it vice versa also too. i know as a fact this cant be normal operations. we both have the same alarm, viper model 3000, only the 2 way remote will do this. the spare remote doesnt have this problem at all. my friend told me to get out of range and press my transmitter butting about 10-20 times. he said this will work and the signal/code will be randomized, is this true?
maybe i have a bad remote?, bad unit? or could it be both systems??
i tried reset everything to default settings, add my remote 4 times to the system, removed the battery on one of the remote while programming/add the transmitter to the proper car.
any help would be greatly appriciated...
Car: honda accord 94 & acura integra 93
Alarm: Viper model 3000
BTW, i installed the alarms 1 day apart, does that effect anything? i got scared my car might get breaking into becuase my sisters car got broken into the night before i installed the alarm.
dare_ds69
Silver - Posts: 419
Posted: October 05, 2005 at 5:53 AM / IP Logged
well you have to do is erase all the remotes in both cars, and program it again and if you have the bitwritter lock the remotes so nobody can add a remote in you car.
how own your mind, control your life.
MECP certified. always use a DMM
hondaccord94
Member - Posts: 11
Posted: October 06, 2005 at 12:33 AM / IP Logged
I have alreayd done that, after deleting all transmitter, the system revert back to default settings. same thing happens. anyone else have advice or solution to this problem? thanks!
kgerry
Platinum - Posts: 3,455
Posted: October 06, 2005 at 6:01 PM / IP Logged
have you tried programming one for code hopping on and the other for code hopping off?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
hondaccord94
Member - Posts: 11
Posted: October 07, 2005 at 2:28 PM / IP Logged
will turning "code hopping" off will effect anything as secutity wise?
hondaccord94
Member - Posts: 11
Posted: October 09, 2005 at 8:27 PM / IP Logged
alright same problem is occuring for me. im getting pretty sick of this and looks like no one else has this problem. i giving it one more shot before im going to return one of the alarm and getting a different one.
