Anybody install remote start 05 Tacoma
je3169
Copper - Posts: 73
Posted: October 06, 2005 at 4:42 AM / IP Logged
I have a code alarm CA430 it uses the factory remote to start the truck i bought a 556u and looking at it i only have to use 3 wires the (red) +12 (black) -ground and the blue wire that hooks to the -output of the R/S.the R/S has a wire to disable the factory alarm but The truck did not come with a factory alarm just keyless entry so i don't think i need to disable anything any other help or tips would be great .
TIA John
Platinum - Posts: 12,488
Posted: October 06, 2005 at 10:02 AM / IP Logged
I have a Tacoma and the installation was easy. I have the double cab 4x4 6 speed manual. If you only have the keyless entry system then all you have to do is use the universal bypass module and leave the grey valet key in the module. Make sure that you have the key in the sweet spot of the module for proper remote start everytime.
je3169
Copper - Posts: 73
Posted: October 06, 2005 at 2:44 PM / IP Logged
What did you do about the 2nd starter wire did you just use a jumper or did you use a diode
John
Chris Luongo
Platinum - Posts: 3,746
Posted: October 06, 2005 at 4:11 PM / IP Logged
Can you find a link or pic of the CA430? I install Audiovox remote starters all day, and I think your unit is simply a rebadged Audiovox---if so, I can help there.
The Tacoma is not a particularly hard car to do a remote start on. It comes apart fairly easily and the wires you need are not hard to find. But if you're new at it, dealing with the immobilizer key can sometimes be frustrating.
By the way, that key is not included on the very, very base trucks--- are you sure yours has it?
I'll admit that I just jumper the two starter wires together. It goes contrary to the way the car was designed, but I luckily haven't had a problem yet.
One catch to this whole deal, though-------Toyota remotes don't work with the car running. It sucks if you remote start the car, and then have to use your key to open the door manually. If it were me, I'd get rid of the unit you have, and buy a remote start with its own remotes, with its own keyless entry, and forget the factory remotes.
je3169
Copper - Posts: 73
Posted: October 06, 2005 at 8:28 PM / IP Logged
Thanks for the info
Well got it done the unit is made by Code Alarm not to bad of an install and ya the remotes don't work when the car is running i need to find the wire that charges the keyless entry when the car is running but it works hit the lock button twice and that turns the R/S on runs for 12 or 25 min turns the parking lights on when in R/S not bad for 80 bucks has lifetime warrenty I also jumpered the 2 start wires all and all i am happy with it.
John
datatechent
Member - Posts: 11
Posted: October 06, 2005 at 9:31 PM / IP Logged
do yo know if the 4runner has a second start wire ? and did you ever find that wire that powers the Keyless entry when the car is running ?
je3169
Copper - Posts: 73
Posted: October 06, 2005 at 9:45 PM / IP Logged
What year is the 4runner and no i have not found the wire yet i am going to start a new post on now.
John
datatechent
Member - Posts: 11
Posted: October 06, 2005 at 11:14 PM / IP Logged
its a 2004 4runner
je3169
Copper - Posts: 73
Posted: October 06, 2005 at 11:36 PM / IP Logged
Well acording to the diagram there is only 1 starter wire for the 2004 4runner.
John
datatechent
Member - Posts: 11
Posted: October 06, 2005 at 11:48 PM / IP Logged
what kind of diagrams do you have for the 2004 4runner ? can you e-mail them to me ? datatechent@yahoo.com thanks
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
