focus auto start?
dougie109
Member - Posts: 25
Posted: October 13, 2005 at 2:50 PM / IP Logged
hey guys.. nice to meet you. im new here.. i have a Carvox alarm, keyless,auto start.. took it to the shop to get installed.. had to place the key under the hood and all that stuff.. now.... they got EVERYTHING work untill the autostart.. it turns over fine.. however after that.. it then disengages the starter... and then all of a sudden it will reengage the starter... someone said i gotta place the tach wire to the...
ignition coil (fuel injector)
distributor wire
oil sensor wire
now.. im wondering just why this is happening?  i undersatnd the modual is sapposed to check to see if the car is running.. but the thing is.. when im driving it.. i will hit a button to check the status of the car.. and it will say running? so im not sure what else is going on here??? but doesn;t that mean that the tach is alrady hooked up or?
any information on this would be EXTREMELY great. thanks for your time
Douglas
sneakycyber
Silver - Posts: 413
Posted: October 13, 2005 at 3:09 PM / IP Logged
that doesnt mean that tach is hooked up. It could be sensing the voltage increase when the car is running. You should always hook up a tach wire. The tach wire doesnt have to be from the distributor it can also be from an injector. Also I have never heard anyone hooking up a tach wire to a oil sending unit. An oil sending unit uses oil pressure to increase or decrease a resistance thus changing the voltage to the guague or light. The voltage doesnt ocilate or pulse.
thepencil
Gold - Posts: 1,526
Posted: October 13, 2005 at 3:11 PM / IP Logged
What year is the car? I will assume it is 2000 or newer.
The remote starter will disengage once the brake is apply unless the brake wire is not connected probably on your alarm and starter unit.
The TACH wire will monitor if the is running.
Yes, they can be found at "ignition coil (fuel injector)
distributor wire". The TACH wire has to be learned(program into the unit).
The wire diagram below give you a good indication where it can be found.
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|gray/black          |+ |ignition harness            |
|        IGNITION|GREEN/ YELLOW        |+ |ignition harness            |
|        ACCESSORY|yellow              |+ |ignition harness            |
|       POWER LOCK|BLACK/ red           |- |drivers kick panel          |
|     POWER UNLOCK|BLACK / YELLOW        |- |drivers kick panel          |
|       LOCK MOTOR|yellow/black        |   |drivers kick panel          |
|     UNLOCK MOTOR|WHITE/ black        |   |drivers kick panel          |
|    DISARM DEFEAT|WHITE/ black        |   |passengers kick panel       |
| PARKING LIGHTS +|orange / YELLOW       |   |headlight switch            |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|grn/blu(L),grn/yel(H|+ |steering column *3          |
|     DOOR TRIGGER|BLACK/ blue          |- |low in drivers kick panel   |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|BLACK/ white        |- |trunk light                 |
|        HOOD PIN|BLACK / YELLOW *4     |- |keyless module *1           |
|TRNK/HTCH RELEASE|BLACK / YELLOW        |- |switch or keyless module *1 |
| FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|BLACK/ green        |   |ignition coil               |
|      SPEED SENSE|WHITE/ green        |   |radio                      |
|       BRAKE WIRE|lt. GREEN/ red       |+ |brake switch *2             |
|     HORN TRIGGER|BLACK/ blue          |- |steering column             |
|           WIPERS|WHITE/ green        |+ |steering column             |
| LF WINDOW UP/DN|yellow - white      |A |in drivers door at motor    |
| RF WINDOW UP/DN|yel/pur - wht/pur   |A |drivers switch or kick panel|
| LR WINDOW UP/DN|yel/blu - wht/blu   |A |drivers switch or kick panel|
| RR WINDOW UP/DN|yellow - white      |A |drivers switch or kick panel|
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|ORANGE / black (thick)|+ |radio                      |
|     RADIO GROUND|blk/yel & blk/grn   |- |radio                      |
|     RADIO SWITCH|YELLOW /GREEN        |+ |radio                      |
| RADIO ILLUMINATE|ORANGE / black (thin) |+ |radio                      |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|wht/blk - gry/blk   |   |radio                      |
|       RF SPEAKER|wht/red - gry/red   |   |radio                      |
|       LR SPEAKER|wht/pur - gry/wht   |   |radio                      |
|       RR SPEAKER|white - gray        |   |radio                      |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555S to bypass. *1 Keyless module is behind the glove box to the right. *2 To meter the brake wire, must turn ignition on. *3 Low beam at the headlight switch is GREEN/ red. *4 Only if equipped with factory alarm.
Be careful whose advice you buy, but be patient with those who supply it.focus auto start? -- posted image.
dougie109
Member - Posts: 25
Posted: October 13, 2005 at 3:12 PM / IP Logged
aight cool.. i will give it a shot if they havent alrady hooked it up.. they said they have never seen this system.. would the tach wire cause it to retry to start??? after the engine is ALREADY idling?
thepencil
Gold - Posts: 1,526
Posted: October 13, 2005 at 3:17 PM / IP Logged
Yes it can if the tach signal has a low reading
dougie109
Member - Posts: 25
Posted: October 13, 2005 at 3:18 PM / IP Logged
ok perfect. so the tach wire which is appearently purpule.. needs to be connected to witch wire and where is it found? sorry i dont see fuel injector / distruiptor wire color either?
thanks for all the help. hopfully this will pull through for me
regards
Douglas
