What Gauge Wire for Electric/Power Windows?
aduk
Member - Posts: 34
Posted: October 13, 2005 at 3:28 PM / IP Logged
hi,
what gauage cabling should i use for my power window loom, thanks
sneakycyber
Silver - Posts: 413
Posted: October 13, 2005 at 3:29 PM / IP Logged
Uh I think you mean gague of wire. In wich case 12-16 guage would be fine. If you really ment wire loom use the smallest that will fit around the wire.
aduk
Member - Posts: 34
Posted: October 13, 2005 at 3:37 PM / IP Logged
so 16 gauge will be able handle the amp draw? its for the wire that goes from the battery to the switch then to the actuator.
sneakycyber
Silver - Posts: 413
Posted: October 13, 2005 at 3:53 PM / IP Logged
Actually I would reccomend 12 guage. I shouldnt have posted 12-16 thats my bad.
infinkc
Copper - Posts: 438
Posted: October 13, 2005 at 4:41 PM / IP Logged
i would reccomend anything larger than your stock wiring guage, if you are running the 12v longer than 4 ft, i would use 12 or 10 guage min. 10 is a overkill sometimes, unless you have a 4 door with sunroof all being activated at the same time.
aduk
Member - Posts: 34
Posted: October 13, 2005 at 6:03 PM / IP Logged
hi, it's only for a two door, the motors and switches are from a higher spec version of my car (Fiat Punto), the wiring that is on the door wiring loom doesnt seem to be as high gauge as 10 i would say it looks more like 12 or 14. would it be too dangerous or risky to use 16?
profuse007
Gold - Posts: 2,015
Posted: October 13, 2005 at 8:14 PM / IP Logged
14guage will be fine. remember use the appropriate fuses to protect your wirings.
Houston,TX
