About Iginition 2?
equate
Copper - Posts: 118
Posted: October 14, 2005 at 1:55 AM / IP Logged
When cranking, does ignition 2 have power on it?
KarTuneMan
Platinum - Posts: 7,056
Posted: October 14, 2005 at 2:11 AM / IP Logged
Second ignition will test one of two ways. It will test with the key switch in run position only, or will test just like main ignition. Like main ignition, it will never show power in the accessory position. If the second ignition shows power only in the run position then the accessory output of a remote start device may be used to power the wire.
Hornshockey
Silver - Posts: 520
Posted: October 14, 2005 at 2:13 AM / IP Logged
are you talking about the wire in the vehicle's ignition harness; or the output wire from a specific remote starter?
either way; need vehicle info and RS info
generally ignition wires are powered during crank; acc wires are powered in run position, off during crank; you can always test with a DMM
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
equate
Copper - Posts: 118
Posted: October 14, 2005 at 2:14 AM / IP Logged
I knew this. I am asking when engine is cranking, is there power on 2nd ignition ?
thepencil
Gold - Posts: 1,526
Posted: October 14, 2005 at 8:37 AM / IP Logged
Yes there is.
equate wrote:
KarTuneMan wrote:
<TABLE height="100%" cellSpacing=0 cellPadding=0 width=400><T>
<T>
<TR>
<TD width=50></TD>
<TD width=300>
<FONT face=arial size=2>Second ignition will test one of two ways. It will test with the key switch in run position only, or will test just like main ignition. Like main ignition, it will never show power in the accessory position. If the second ignition shows power only in the run position then the accessory output of a remote start device may be used to power the wire. </TD>
<TD width=50> </TD></TR></T></T></TABLE>
Be careful whose advice you buy, but be patient with those who supply it.About Iginition 2? -- posted image.
sneakycyber
Silver - Posts: 413
Posted: October 14, 2005 at 9:41 AM / IP Logged
Well there could be 2 ignition 1s and 2 ignition 2's. in wich case there would be 4 wires that could be pos in run, off in acc position and 2 in crank. Normally Ign 2 is not powerd during crank however I think some new cars this has changed. Some even drop out when starting and there is no start wire. So as you can see without knowing what vehicle your working were not sure what you have. About Iginition 2? -- posted image.
equate
Copper - Posts: 118
Posted: October 15, 2005 at 2:13 PM / IP Logged
I am talking about the wire in the vehicle's ignition harness.
But you give me a new question, so what's starting oder? Acc-->IG1/IG2-->IG1/START-->IG1/IG1/ACC?
mo12v
Posted: October 15, 2005 at 3:15 PM / IP Logged
May be better to state Vehicle Year, Make & Model........
There are different IGNITION setups and how they function when you turn the key to ON & Start
MO
cntrylvr79
Silver - Posts: 582
Posted: October 15, 2005 at 7:36 PM / IP Logged
Since I'm not really understanding the answers posted here I'll add my 2 cents.  The second ignition in a car may have power durring crank, but they don't always have power in crank.  As for the order of output at least for dei systems it goes IG1/IG2, Start, strat drops and accys are powered.
Cause I'm So white and nerdy...
First Class Certi-fried installer
equate
Copper - Posts: 118
Posted: October 15, 2005 at 8:58 PM / IP Logged
So how about the 2nd ignition output from remote starter? Does it have output during cranking?
Sunday, August 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
