Remote start for 2003 Ford diesel
cemery
Posted: December 10, 2002 at 7:21 PM / IP Logged
                       Installing remote start by Bulldog on 2003 Ford F250 diesel. Am looking for wiring diagram for pickup
Emery & Sons Equipment Manager
mxxmikexx
Silver - Posts: 796
Posted: December 10, 2002 at 7:26 PM / IP Logged
have fun. i just did one and couldnt find a tach wire anywhere, i got 10 different stories from 10 different people
kickyride
Copper - Posts: 100
Posted: December 10, 2002 at 9:26 PM / IP Logged
Yeah, you're not really going to find a tach wire on a diesel. The tachometer is run off of a crangle angle sensor and that doesn't really work with most remote starts. Plus, on the new vehicles, alot of that is done via the vehicle's data bus. The best way is to just use something that has a good current sensing circuit and some type of glow plug delay. Here's some info on a '02 truck but it should match up.
12volts
Remote start for 2003 Ford diesel -- posted image.
 yellow & lt. grn/pur
 ignition harness
Starter green   +  ignition harness
Second Starter none
Ignition RED / lt. green   +  ignition harness
Second Ignition none
Third Ignition none
Accessory gry/yel & RED / blk   +  ignition harness
Second Accessory blue/lt. green   +  ignition harness
Keysense
Power Lock        Remote start for 2003 Ford diesel -- posted image.
Power Unlock        Remote start for 2003 Ford diesel -- posted image.
Lock Motor pink/black    VSM   Remote start for 2003 Ford diesel -- posted image.
Unlock Motor RED / orange    VSM   Remote start for 2003 Ford diesel -- posted image.
Parking Lights+ brown    headlight switch
Parking Lights- none
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BLACK/ lt. blue   +  either kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin none
Hood Pin none
Trunk/Hatch Release none
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock none
Tachometer     ignition coils   Remote start for 2003 Ford diesel -- posted image.
Wait to start
Brake Wire lt. green   +  brake pedal switch
Parking Brake
Horn Trigger blue   -  steering column or VSM   Remote start for 2003 Ford diesel -- posted image.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Mike
Sales/Tech Support - KICKYRIDEoCOM mobile electronics
MECP 1st class-Security Specialist
