F150 Heritage
wyoron
Posted: October 30, 2005 at 3:31 PM / IP Logged
Getting ready to install Bulldog 6002 with 791 bypass for remote start. The 04 Heritage usually requires to look up everything for 03 due to body style and design. Should I plan on using 03 or 04 wiring diagrams and color codes? Any special situations I should be prepared for?
mo12v
Posted: October 30, 2005 at 4:18 PM / IP Logged
2004 Heritage
Constant 12 voltsYELLOW & GREEN/ VIOLETIGNITION SWITCH HARNESS
Ignition 12 voltsD BLUE/L GREENIGNITION SWITCH HARNESS
StarterRED / L BLUEIGNITION SWITCH HARNESS
Dome LightBLACK/ BLUE (+) DRIVERS& PASSENGERS KICK PANEL *
Trunk Pin SwitchN/A
Parking LampBROWN / WHITE (+)HEADLIGHT SWITCH **
Power LockPINK / YELLOWDRIVER KICK PANEL ABOVE ***
Power UnlockPINK/L GREENPARKING BRAKE HANDLE
* Dome Light:(-) Pin Switch Wire Drivers BLACK / YELLOW All Others BLACK/ PINK Located In A 26 Pin Plug At The G.E.M. Above The Fuse Box. ** Parking Lamp Wire Also Located At Six Pin Connector Under Drivers Dash. *** W/ OEM Keyless Entry........Negative Pulse Door Lock .
W/out OEM Keyless Entry ......Reversal Rest At Ground Door Locks.
DoorLock Info: Due To Accessory Power Loss At Generic Electronic Module,Power Door Locks Will Become Inoperable 2 Minutes After Last Door Is Locked And Closed. To wake up the G.E.M Send A Negative Pulse To The YELLOW/BLACK Driver Door Pin Wire With the Unlock Pulse. Diode Isolate Cathode(Band Side) Of Diode Faces Away From Vehicle Wires.You May also Get It At The Drivers Door Boot.
**ANTI-THEFT COLORS:GROUND-BLACK/ LT.BLUE 12VOLTS-RED / LT.GREEN RX SIGNAL-GRAY/ORANGE TX SIGNAL-WHITE/ LT.GREEN
Accessories
Window UpD\ WHT/BLK P\ TAN/BLU D\ YEL/BLU P\ RED / BLK @ MAIN SWITCH
Window DownF/ ORG/WHT F/ WHT/YEL R/ GRY/ORG R/ YEL/BLK
Ign Key WarnBLACK/ PINK (-)PLUG TO RIGHT OF STEERING COLUMN
Trunk ReleaseN/A
OEM HornD BLUE (-)PLUG TO RIGHT OF STEERING COLUMN
HeadlightsRED / YELLOW (+)AT HEADLIGHT SWITCH
OEM Alarm Arm
OEM Alarm DisarmGREEN/ VIOLET (-)AT G.E.M. ABOVE PARKING BRACKET
Reversal Rest At Ground Power Window Circuit
OEM Alarm Horn Wire- YELLOW/LT.GREEN At Fusebox Under Hood. OEM Alarm Hood Trigger- None Listed In Shop Manual.
Remote Start
Tach SignalD BLUE/L GREEN (4.2L)AT COIL PACK ON ENGINE *
Ignition #2GRAY / YELLOWIGNITION SWITCH HARNESS
Ignition #3RED / BLACKIGNITION SWITSH HARNESS
AccessoryBLACK/ LIGHT GREENIGNITION SWITCH HARNESS **
Neutral SafetyNONE GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightL GREEN (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightBLACK/ PINK (+)AT SWITCH ON TRANSMISSION
Rear Window DefrostBLUE/ORANGE (-)AT SWITCH
* Wire Color Changes To L GREEN / WHITE On 4.6L and 5.3L Engines. ** Must Be Powered When Remote Started.
Immobilizer Bypass Diagram. OEM Keyless ACC Wire: BLACK/ PINK At GEM Module Located Above The Fuse Box Fuse Box.
MO
wyoron
Posted: October 30, 2005 at 8:44 PM / IP Logged
Mo,
Great info, Thank You!
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
