Neutral Safety Switch, 89 Mustang
Nebey
Member - Posts: 6
Posted: November 13, 2005 at 3:36 PM / IP Logged
Hey so I am installing a remote starter in my 89 mustang, I have got it all wired in, everything works good, except I havn't figured out what to do about the neutral safety switch.  I think I found it, has 2 sets of wires going into it, its white plastic, and seems to move as push in the clutch.  do I connect 2 wires together? if so which ones? so I somehow mechanically close the switch? remove it and relocate it?
IThanks for your time
Mike
Nebey
Member - Posts: 6
Posted: November 13, 2005 at 3:53 PM / IP Logged
ahh ok, maybe I was miss-reading the printout.... ok so the clutch switch
KarTuneMan
Platinum - Posts: 7,056
Posted: November 13, 2005 at 3:57 PM / IP Logged
What are you installing (make and model)
Nebey
Member - Posts: 6
Posted: November 13, 2005 at 5:12 PM / IP Logged
I am putting a remote start into my 1989 Ford Mustang, with a manual transmission.  I want the car to be ablt to start without having to push the clutch in.
The remote start is by Polar Start I do believe... something like that anyways... I have looked at it so much, I have fogotten...
05gt
Silver - Posts: 628
Posted: November 13, 2005 at 7:41 PM / IP Logged
just bypass the clutch with a relay
KarTuneMan
Posted: November 13, 2005 at 9:57 PM / IP Logged
What type of R/S......?
