97 Mazda Protege Door locks
davidachew
Member - Posts: 31
Posted: November 15, 2005 at 8:52 AM / IP Logged
I’m installing a Commando 550 Alarm/remote entry system in a 1997 Mazda protégé. According to the wire map this car has a single wire door lock\unlock system. I’m not all too familiar with this system, I’ve been looking around and am curious if the " Nissan's Single Wire '91-'95 using 1relay and 1 diode " is the proper way to wire this? If not can you point me in the right direction.             Thanks for your help.
mo12v
Posted: November 15, 2005 at 9:10 AM / IP Logged
Some units require a Stronger GROUND from thier Lock / Unlock wires, inwhich you would need 2 Relays:
Lock requires negative trigger through a 4.7K resistor, Unlock requires a negative trigger to the same wire.
2 SPDT RELAYS:
LOCK:
PIN 87 = Ground
PIN 30 = 4.7 ohm Resistor to Vehicles WHITE / Blue wire
PIN 85 = Negative Lock Output Cammando
PIN 86 = Constant 12 volt ( + )
UNLOCK:
PIN 87 = Ground
PIN 30 = to Vehicles WHITE / Blue wire
PIN 85 = Negative UNLock Output Cammando
MO
davidachew
Member - Posts: 31
Posted: November 15, 2005 at 3:51 PM / IP Logged
The wire map says 1k resistor is it suposed to be 4.7k?
mmouse
Member - Posts: 6
Posted: November 15, 2005 at 4:31 PM / IP Logged
You will need to run the relays. Run the resistance as the wiring guide calls for, if it doesn't work then u need to play around with it until u get it right.
davidachew
Member - Posts: 31
Posted: November 16, 2005 at 8:33 AM / IP Logged
Awesome, Worked great. Thanks for the help.
Another quick question regarding the dome light.
200ma - coming from commando control module. - system on car.
Do I just hook the door switch and dome light wires up together to the BLACK/ red door switch wire? and if so do I need a relay for the dome light wire, or will 200ma be enough to function?
Thanks again
mo12v
Posted: November 16, 2005 at 9:19 AM / IP Logged
Usually you would want a Relay to supply the GROUND neccessary for Dome Light
PIN 87 = Ground
PIN 30 =  BLACK / Red wire
PIN 85 = Negative Dome Lite Output Cammando
MO
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
