Weird Compustar Problem
airride
Member - Posts: 9
Posted: November 15, 2005 at 6:10 PM / IP Logged
Had a strange problem today with my compustar, went to start it after work and it wouldnt start, so i got home, checked the wiring, no obvious problems, it would lock and unlock but thats it, no siren, no light flash, i tried reprogramming the remote and now it works fine, had to hit the tach button too to get the remote starter to work correctly again. What would cause something like this? Its a 2w8000fm-as in a 1998 eagle talon turbo, have had it in there about a year now without any problems.
Platinum - Posts: 12,488
Posted: November 15, 2005 at 8:13 PM / IP Logged
Have had this problem with a few of the systems. Ghost in the system is what I blame it on. No real reason for it to loose the programing and it wasn't in valet mode either so not sure what the problem was.
jdeezay
Member - Posts: 28
Posted: November 16, 2005 at 6:43 PM / IP Logged
compustar has had a bad run of 900 MHZ 2 way remotes you probibly have one it started this time last year
airride
Member - Posts: 9
Posted: November 17, 2005 at 12:04 AM / IP Logged
what 2 way remotes will work with the cm3000? i need a new one cause i cracked the display on mine
madgamer
Member - Posts: 6
Posted: December 08, 2005 at 4:13 PM / IP Logged
Depends on the antenna you have... The CM3000 brain is used in several computar models, including the 2WSS-AS, 2W900FM-AS, 2WFM-AS, etc...
Now look at the antenna you have in your vehicle, on the label it will tell you if its the SS, 900Mhz or 433Mhz model. From there, just call a dealer and order the approperiate remote.
Happy Holidays!
