98 4runner Remote Start
quebert00
Member - Posts: 7
Posted: December 05, 2005 at 11:29 AM / IP Logged
I am going to be installing a remote start on a 98 4runner. Does anyone know how to bypass the factory alarm? The wiring diagrams I have don't have anything listed for Factory Arm or Disarm. I believe this unit is a RS-3000. Let me know.
Thanks in advance!
quebert00
Member - Posts: 7
Posted: December 05, 2005 at 11:32 AM / IP Logged
Or does this unit only need a lock/unlock pulse to disarm and rearm the alarm?
northern
Copper - Posts: 154
Posted: December 05, 2005 at 12:28 PM / IP Logged
Just did a 97 4runner. But that model did not have a factory alarm.
quebert00
Member - Posts: 7
Posted: December 05, 2005 at 8:17 PM / IP Logged
Anyone else have an idea?
mobileworks
Copper - Posts: 136
Posted: December 05, 2005 at 10:27 PM / IP Logged
Remote Starter Wiring Colors and Notes
Function
Vehicle  ColorLocation
Start:
BLACKIGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ REDIGNITION SWITCH HARNESS
Ignition  #2:
BLACK / YELLOWIGNITION SWITCH HARNESS
Ignition  #3:
N/A
Accessory:
BLUE/REDIGNITION SWITCH HARNESS
Brake  Light:
GREEN / WHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACKAT IGNITER ON PASS. WHEELWELL *
Parking Lights:
GREEN (+)13 PIN CONNECTOR AT FUSE BLOCK **
Headlights:
RED (-)AT HEADLIGHT SWITCH **
Diesel  Glow Plug:
Clutch  Bypass Wire:
NOTES: * BLACK Tach Wire Also Found In Data Link Connector On Driver Side Of Engine (4 Cyld.) Or At Engine Control Module Located Behind Pass. Dash (6 Cyld.) Or Can Also Be Found In 26 Pin Connector In Pass. Kick Panel On Both.
Alarm and Keyless Entry Wiring Colors
Function
Constant  +12 Volts:
WHITE/ RED & WHITE
OEM Alarm Disarm:
N/A
IN SCHEMATICS
Dome  Lights/Superv:
BLACK/ WHITE (-)
26 PIN CONNECTOR IN DRIVER KICK PANEL
OEM Horn:
GREEN/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
RED / WHITE
13 PIN BLUE CONN. IN DRIVER'S KICK ***
Power  Unlock:
RED / YELLOW
Trunk  Release:
BLACK / YELLOW
26 PIN CONN. IN DR. KICK PANEL
Alarm  Input Wire:
BLACK/ WHITE (-)
NOTES: ** Fuse Block Located In Driver Dash. *** Child Safety Locks: RED / BLUE (-) In Same Conn. As Door Lock Wires Above.
secureauto
Copper - Posts: 197
Posted: December 05, 2005 at 10:32 PM / IP Logged
Is it a keyless upgrade? does it have a light pod under the dash? It could also be a factory Toyota upgrade alarm installed at the dealer, those are usually T-harnessed.
ASE Certified
quebert00
Member - Posts: 7
Posted: December 06, 2005 at 11:11 AM / IP Logged
I believe it is a factory Toyota alarm installed at the dealer. The unit is under the drivers seat and it does have the secuirty light on the console. It does look as though all of the wires where connected with T-Taps.
What does this mean??OEM Alarm Disarm: N/A IN SCHEMATICS
Mike M2
Platinum - Posts: 2,652
Posted: December 06, 2005 at 3:10 PM / IP Logged
Any Toyota alarm starting with RS is dealer installed. I know they do connect to the keysense, but i'm not sure if it will disarm the alarm. Honestly, you may not have to. Most only have a starterkill and no shock sensor, just like an aftermarket. If that's the case just apply your starter wire after the the T harness at the ignition switch and let it stay on....
Mike M2
Tech Manager
CS Dealer Services
Scott35
Silver - Posts: 258
Posted: December 06, 2005 at 5:06 PM / IP Logged
On that kind of alarm you could just remove it.
Tacomacrew
quebert00
Member - Posts: 7
Posted: December 06, 2005 at 7:03 PM / IP Logged
It does have a shock sensor I saw it under the dash. The alarm will sound if you hit the glass to hard or open a door while armed.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
