2000 Mazda MPV
ddeguzman
Member - Posts: 9
Posted: December 17, 2002 at 11:05 AM / IP Logged
Do I need a bypass module when installing a remote start for a 2000 Mazda MPV
jrilla
Gold - Posts: 1,498
Posted: December 17, 2002 at 11:14 AM / IP Logged
Yes2000 Mazda MPV -- posted image.
J Rilla
Owner/Installer
mxxmikexx
Silver - Posts: 796
my techsoft program says it has an immobilizer system that needs to be bypassed, says to refer to document #1061...whatever that is.  sorry i couldnt give you all the info
jrilla
Gold - Posts: 1,498
Posted: December 17, 2002 at 11:17 AM / IP Logged
I bet you thought I was just going to leave you hanging.
You have a Transponder based anti-theft system.  You can get a No Key Required bypass module from http://www.bypasskit.com/pkm1.asp?cid=17 , or even one that requires an additional key, or there are many other places to get the modules that require keys.
J Rilla
Owner/Installer
ddeguzman
Member - Posts: 9
Posted: December 17, 2002 at 11:33 AM / IP Logged
thanks
jrilla
Gold - Posts: 1,498
Posted: December 17, 2002 at 11:34 AM / IP Logged
No Problem, they are not too difficult to install, just ask if you need any help.
J Rilla
Owner/Installer
ddeguzman
Member - Posts: 9
Posted: December 23, 2002 at 1:01 PM / IP Logged
this has a single wire lock/unlock with 2.2k resistance.  Do I need a relay?
If I do, need help  with wiring.  Thanks
jrilla
Gold - Posts: 1,498
Posted: December 26, 2002 at 3:01 PM / IP Logged
Yes use a relay with the resistor
J Rilla
Owner/Installer
