Power Lock Motor Lock?
tintman97
Copper - Posts: 113
Posted: December 08, 2005 at 2:32 PM / IP Logged
What is the diffrence? also doing a 98 maxima double pulse unlock i know but when we test the wires there is no drop in voltage when we hit the lock or unlock stays the same?  These are negitive pulse so it should show 12 volts all the time till the switch gets hit.  This does absolutly nothing?  Any ideas
Snapper
guatemalanboy
Member - Posts: 18
Posted: December 08, 2005 at 2:51 PM / IP Logged
hey tintman have fun hope this helps u out and to answer your question power lock will rest at ground and do 12 volt when switch is hit, lock will do ground if the switch is hit if its (-) or do (+) if the switch is hit
12volts wht/red - wht/pur   +  ignition harness
Notes: The ignition harness wires change color at a plug. The above listed colors show both sides of the plug.
Starter blk/yel - blk/wht   +  ignition harness
Second Starter grn/blk - RED / blu   +  ignition harness
Ignition blk/wht - blk/red   +  ignition harness
Second Ignition
Third Ignition
Accessory RED / yel - red   +  ignition harness
Second Accessory blue - wht/blu   +  ignition harness
Keysense
Power Lock lt. GREEN/ red   -  in drivers door at switch
Power Unlock GREEN/ YELLOW   -  in drivers door at switch
Notes: Requires a double pulse.
Lock Motor BROWN / white    in drivers door at switch
Unlock Motor brown    in drivers door at switch
Parking Lights+ RED / green    steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white   -  low in drivers kick
Dome Supervision
Trunk/Hatch Pin purple / YELLOW   -  drivers kick or BCM
Notes: The BCM (body control module) is located just below the radio.
Hood Pin yellow/black   -  BCM
Trunk/Hatch Release purple / YELLOW   -  low drivers kick
Notes: Must use a relay to interface with this circuit.
Power Sliding Door
Factory Alarm Arm arms w/ lock
Factory Alarm Disarm disarms w/ unlock
Disarm No Unlock
Notes: A single negative pulse to the unlock wire will disarm without unlocking.
Tachometer WHITE/ green   ac ECM
Notes: The ECM is located in the front of the center console on the transmission hump. The wiring is easily reached by removing the small black panel just to the front of the center console on the passenger side. the wire is in the middle row, 7th one in from the left.
Wait to start
Brake Wire RED / green   +  at brake switch
Parking Brake
Horn Trigger GREEN / WHITE   -
Memory Seat 1
Memory Seat 2
Memory Seat 3
Power Lock Motor Lock? -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
No
Type:
N/A
Part #: N/A
Notes:
100%Guatemalan
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
