2004 350Z alarm/remote start
hardbodys
Copper - Posts: 62
Posted: December 22, 2005 at 6:36 PM / IP Logged
i am looking for an updated wireing diagram (alarm and remote start )
thanks everybody
hardbodys
Craig3708
Copper - Posts: 155
Posted: December 22, 2005 at 6:49 PM / IP Logged
Nissan | | 350 Z | | 2003 - 2005
Remote Starter Wiring Colors and Notes
FunctionVehicle ColorLocation
Start:WHITE/ Red (+)
Ignition #1:BLACK/ Red (+)Ignition switch harness*
Ignition #2:Ignition switch harness
Ignition #3:Ignition switch harness
Accessory:WHITE/ Black (+)Ignition switch harness
Brake Light:Pink/Blue (+)
Tach Signal:
Parking Lights:RED / Blue (+)Drivers kick panel
Headlights:
Diesel Glow Plug:N/A
Clutch Bypass Wire:
Notes:*This vehicle may be equipped with a Transponder Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. **This vehicle is equipped with two start wires. Both must be connected to remote starter wire in order for veh
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts:WHITE/ Blue (+)Ignition switch harness
OEM Alarm Disarm:No info. available
OEM Horn:GREEN/ Black (-)Steering column harness
Power Lock:Red (-)Driver door module inside the door***
Power Unlock:Lt.Blue (-)Driver door module inside the door***
Trunk Release:Pink (-)Brown plug at the BCM****
Alarm Input Wire:
Notes:***These are the driver door key cylinder wires, test the wires while turning the key in the driver door. See Note #201 Negative Trigger Door Locks. ****The Body Control Module (BCM) is in the drivers kick panel below the fuse box.
Craig
hardbodys
Copper - Posts: 62
Posted: December 22, 2005 at 7:10 PM / IP Logged
thanks but do you know if i will need a relay for the clutch switch ?
hardbodys
Craig3708
Copper - Posts: 155
Posted: December 22, 2005 at 7:18 PM / IP Logged
I'm not sure. Find the clutch switch and determined whether it is pos or neg. If your remote start unit has a neg output for the clutch and the clutch switch is neg , no you will not need a relay. If they are opposite then yes you will need to change the polarity through a relay.
Craig
hardbodys
Copper - Posts: 62
Posted: December 22, 2005 at 9:25 PM / IP Logged
thanks thats what i needed to know :)
hardbodys
Evolution-UK
Copper - Posts: 192
Posted: December 23, 2005 at 2:06 AM / IP Logged
for the locking you dont have to go into the door. There are wires in the body->door harness that you can tap into. Open circuit-pos pulse. I cant remember the colors but they arent hard to find.
hardbodys
Copper - Posts: 62
Posted: December 28, 2005 at 5:42 PM / IP Logged
i have a VIPER 791XV alarm with remote start and the Z has 2 starter wire's but the alarm 1 starter side wire and 1 key side wire, what do i need to do to mke this work and have the 556UW BYPASS .
hardbodys
hardbodys
Copper - Posts: 62
Posted: December 28, 2005 at 10:40 PM / IP Logged
ok does any one got an diagram for the cluch bypass for remote start on 350z
hardbodys
hardbodys
Copper - Posts: 62
Posted: December 29, 2005 at 1:10 AM / IP Logged
thanks guy's for all your help with this project , like i asked before the only thing i need now is a more detailed clutch bypass disgram .
hardbodys
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
