code alarm ca545 wont enter programing
petersen,tim
Member - Posts: 8
Posted: December 30, 2005 at 10:14 PM / IP Logged
just installed code alarm ca-545 and ca-425 master module and am trying to get transmiters programed to unit,dirrections say to hold valet switch down for up to ten seconds and system will chirp 3 times when it goes to program mode,wont chirp and goes to valet mode,any ideas?
petersen,tim
Member - Posts: 8
Posted: December 30, 2005 at 10:49 PM / IP Logged
i have tryed grounding green neg. door input wire and still un able to enter programing mode.
kohara73
Copper - Posts: 192
Posted: December 31, 2005 at 9:10 AM / IP Logged
1.  Make sure have have good ground on door trigger wire.
2. Make sure you have door trigger wire grounded BEFORE you turn on ignition.
3. Make sure you don't press valet switch until ignition is on.
From what it sounds like, you are are not installing the door trigger.  The system needs to see the door open first, before anything else.
Keith
petersen,tim
Member - Posts: 8
Posted: December 31, 2005 at 2:05 PM / IP Logged
got unit to go into programing mode,as it was i needed to hold valet button down longer(through valet mode )to get to programing mode,now everything functions correct,remote start and door entry ect. my only problem left is when i programed tach it learned it but now my check engine light is on,do i need to diode tack wire or ? thanks.
kohara73
Copper - Posts: 192
Posted: December 31, 2005 at 3:57 PM / IP Logged
What kind of car??
Keith
petersen,tim
Member - Posts: 8
Posted: December 31, 2005 at 4:20 PM / IP Logged
2001 dodge ram.
kohara73
Copper - Posts: 192
Posted: January 01, 2006 at 7:53 AM / IP Logged
Try driving it for a few days.  That truck uses OBDII engine management.  If there's not a "real" problem, the light will turn off.  Unless you have a code reader then you can reset the code and see if it comes back.
Keith
Mharvey
Copper - Posts: 76
Posted: January 01, 2006 at 8:59 AM / IP Logged
check to make sure you have both Ignition wires hooked up
petersen,tim
Member - Posts: 8
Posted: January 01, 2006 at 9:43 AM / IP Logged
Keith your GOOD the next time i used the truck the light was out and hasnt come back on since THANKS for your help and taking the time to respond to me Tim
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
