DEI Valet 552T, 2000 Bonneville SSEI
mrneely2u
Posted: January 01, 2006 at 7:43 PM / IP Logged
I just bought this car yesterday and found out that it has a DEI Valet 552T Remote Start on it. After looking that up on yhe net, the remote start has been discontinued and now is a 562T Remote start. The car did not come with a remote and i would like to get a replacement. I have looked under the dash and found the module there with the wires still in contact. What would i need to do in order to get the right remote for this starter. Thx.
MrNeely2u
uffdog
Member - Posts: 45
Posted: January 01, 2006 at 7:59 PM / IP Logged
DesignTech International   send these guys an email company should be able to hook you up  since they made the one in your car
rfd
uffdog
Member - Posts: 45
Posted: January 01, 2006 at 8:01 PM / IP Logged
DesignTech International    email these folks, they made your sys so they should be able to hook you up with a remote
rfd
gus1
Gold - Posts: 1,013
Posted: January 01, 2006 at 10:36 PM / IP Logged
Uhhh..... Design Tech doesen't do DEI parts.
mrneely.... you will require a 474v remote. Available for less than $30 at any DEI dealer.
Gus
mrneely2u
Posted: January 01, 2006 at 10:50 PM / IP Logged
Gus, you are right, i could not find a remote on that DEI website, but this 474v remote, would i have to give the dealer a model number or something off the "Brain" to get the right remote?
MrNeely2u
gus1
Gold - Posts: 1,013
Posted: January 01, 2006 at 11:10 PM / IP Logged
That's because it is not DEI's website.....
Tell the dealer that you have a 552T that you need a remote for. The other thing I just thought of..... they may be triggering it off of the factory keyfob. Try hitting unlock 3 times.
Gus
PS: Just realized I gave you the wrong part number.... you will need either the 471T or the 491T... depending on the date code on the unit. There will be a white sticker on the bottom of the unit..... there will be a letter and number on there..... let us know.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
