2002 Ford Explorer Immobilizer wiring
uniquenigga
Posted: January 17, 2006 at 9:17 PM / IP Logged
Trying to put in a Directed 555P Interface Module for a 2002 Ford Explorer PATS System. Does anyone have a wiring diagram or know the wiring colors of the immobilizer data tap, immobilizer sync tap? Also where are they located at in this vehicle? Any help will be greatly appreciated. Thanks.
-J
uniquenigga
Posted: January 17, 2006 at 10:21 PM / IP Logged
bump
redpeppers
Silver - Posts: 483
Posted: January 17, 2006 at 10:39 PM / IP Logged
r u sure u can use the 555p on that year?  My info from directechs says it takes a 556sw.....and u dont interface into the wires.....u just run the capsule up around the ant ring....in 2001 instead of using the PATS they converted to the SecuriLock
Where theres is a wire there's a way.
uniquenigga
Posted: January 18, 2006 at 5:26 AM / IP Logged
I was told by the seller of the piece that I could, but I guess I got screwed. Is there any way possible to use it? The car will start if the key is next to the ignition so I know there is a chip inside the key. Thanks for all of the help.
-J
redpeppers
Silver - Posts: 483
Posted: January 18, 2006 at 1:44 PM / IP Logged
take it back and trade it for the 556sw
