bitwriter
mobilecustoms
Silver - Posts: 397
Posted: January 21, 2006 at 9:04 PM / IP Logged
is there an instruction manual for the bitwriter 998t and the 2.2 chip? I just got one today and dont really know how to use it.
leades12
Member - Posts: 20
Posted: January 21, 2006 at 9:55 PM / IP Logged
look in the downloads section (to the left under general info) covers the basic operation of the bitwriter, Hope this helps
Les
auex
Platinum - Posts: 5,041
Posted: January 22, 2006 at 12:11 AM / IP Logged
It is really pretty simple.
Plug it in, turn it on, hit read, then hit the up and down arrows to highlight the option, hit select to change the option, then when everything is set up the way you want it hit write, when it pops up the next screen hit select a couple times to change the remote to 0(0 programs all remotes) and then hit write again.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mobilecustoms
Silver - Posts: 397
Posted: January 22, 2006 at 7:47 AM / IP Logged
i looked ther but did not see it
leades12
Member - Posts: 20
Posted: January 22, 2006 at 8:06 AM / IP Logged
try this
998T
Les
mobilecustoms
Silver - Posts: 397
Posted: January 22, 2006 at 8:45 AM / IP Logged
thanks, but the link does not work
kgerry
Platinum - Posts: 3,455
Posted: January 22, 2006 at 8:47 AM / IP Logged
have you actually tried to use it??? you plug it in, turn it on, and off you go...... it's so simple to use a chimp could do it.... use the up/down arrows to move up and down the menu and the BIG button in the middle to change selections....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
mobilecustoms
Silver - Posts: 397
Posted: January 22, 2006 at 8:48 AM / IP Logged
i have, but like the owner recognition part of it, how does that get programed?
leades12
Member - Posts: 20
Posted: January 22, 2006 at 8:50 AM / IP Logged
hmmm, it's on page 2 of the downloads in general info
Les
mobilecustoms
Silver - Posts: 397
Posted: January 22, 2006 at 8:18 PM / IP Logged
thanks a lot... i totally missed that!
