2002 Dodge RAM 1500 keyless system
Quique
Posted: December 28, 2002 at 12:12 PM / IP Logged
Help!.  Just bought a factory keyless system for my 2002 Dodge RAM 1500 4x4 quadcab that includes the 16 pin module with a new xmitter.  My problem is that I cannot find the plug for the module!.  I'd read somewhere that the plug should be somewhere on  the driver's side kick  panel\emergency brake area  but short of taking the whole truck apart, I still can't find the plug!.  Can someone tell me where is this 16 pin plug?.   Thanks!!
Platinum - Posts: 12,488
Posted: December 28, 2002 at 12:29 PM / IP Logged
Try looking way up high in the driver's kick panel area above the brake for a loose molex plug.
Quique
Posted: December 28, 2002 at 12:48 PM / IP Logged
Ooops!  Is a 6 pin plug not a 16 pin plug.  Thank you, Jeff!.  But I still can't find the darn thing!.
DanDan
Copper - Posts: 125
Posted: December 28, 2002 at 3:25 PM / IP Logged
The module plugs into the back of the instrument panel.  After you install it you will have to take it to the dealer and have it hooked up to the DRB tester to program it.  Again the plug is behind the main cluster.  Very easy to install but it will have to be programmed with the tester.
DanDan
Quique
Posted: December 28, 2002 at 4:08 PM / IP Logged
Thank you, Dan Dan!.  You guys are great!.  I surely treasure your support and quick response.  Hopefully I'll be able to find it.  Will keep you posted.
Quique
Posted: December 28, 2002 at 6:38 PM / IP Logged
I guess that I might have to remove the cluster since it is impossible to reach it from underneath.  Lot of work and it's too cold out there!.  Hopefully I don't need to take it to the dealer.  Too costly!.  Will continue tomorrow.
