Viper 791XV Wiring problem
beakerss
Member - Posts: 21
Posted: February 14, 2006 at 3:52 PM / IP Logged
I am having a problem. I have a 2004 Dodge ram standard cab and just aquired this alarm from my business partner. The problem is the remote start ribbon harness. I understand where everything else goes but this ribbon.
pink/white- 200ma (-) prog ign2 acc2 relay turn on
yellow- (+) ignition input to alarm
pink- (-) 200 ma ignition relay turn-on
orange- (-) 200 ma accessory relay turn-on
purple (-) 200 ma starter relay turn-on
ORANGE / black- (-) antigrind/ground when armed output
blue- (-) 200 ma status output.
My understanding was that the satellite relay was for this with the heavy gauge wires and the ribbon that hooks up the satellite to the brain. If anyone could please help me or not by telling me where they go or if they are needed it would be appreciated. Thank you very much in advance!
bazzgazm
Copper - Posts: 113
Posted: February 14, 2006 at 11:45 PM / IP Logged
You're right. you're missing the XRC relay center. This should plug into a ribon harness to the brain giving you your high current outputs (starter, ignition, accessory) and 2 inputs (12v constant)
This can probably be purchased on dei's parts website. go to DIRECTELECTRONICS.CoM and see if you have a link there, should be in the neck of 39.99 retail price
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
