Toyota Matrix Keyless Entry
ohmygodihavenoh
Member - Posts: 7
Posted: February 21, 2006 at 11:22 PM / IP Logged
Hi, a while back a member named Mike M2 told me the following...
"As for the locks, they are very simple in a Matrix. At the drivers kickpanel there is a white plug half way down coming from the door. In it there is a blue/white, thats your lock wire and will require a negative pulse. Also in the plug is a blue / YELLOW, that is unlock. Giving it a single negative pulse will unlock the drivers door. A second pulse will unlock all the other doors. It's just that simple, no relays needed. This makes it easy to have two stage unlock, doesn't it?"
Today I thought that I would verify the correct wiring before installing my unit.  What I found was that a (-) pulse on the blue/white wire does lock all doors, but a single (-) pulse on the blue / YELLOW wire does nothing.  Two consecutive pulse or double pulse (-) on the blue / YELLOW wire unlocks all the doors.  Can anybody help me out on how to get drivers priority unlock to work.  In the worst case I assume that I can rip off the drivers door panel and wire the 1st unlock wire to the motor with a relay and use the 2nd unlock wire from the unit to drive the blue / YELLOW wire.  Does anyone know an easier way to do this.
Also can anybody tell me from the diagram below what the Green Power Unlock wire does, I cant seem to find it.  Does it exist and does it function the same as the blue/white unlock wire?.   Finally does anyone have an idea what the Lock Motor and Unlock Motor blue and red wires do and what 5wi stands for.
Thanks for all your help,
Dave
12volts white (25A), black (15A)  +  ignition harness
Starter red  +  ignition harness
Ignition BLACK/ white  +  ignition harness
Power Lock green  -  driver kick, 10 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlock blue / YELLOW (double pulse)  -  driver kick, 10 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/black (-) in the passenger kick in a 10 pin plug.
Lock Motor blue  5wi driver kick, blue 12 pin plug
Unlock Motor red  5wi driver kick, blue 12 pin plug
Parking Lights+ green  +  driver kick, harness to rear
Parking Lights- GREEN / WHITE  -  headlight switch
Hazards yellow/black  -  flasher relay left of fuse box
Turn Signal(L) GREEN/ black  +  flasher relay left of fuse box
Turn Signal(R) GREEN/ YELLOW  +  flasher relay left of fuse box
Door Trigger red  -  front of fuse box, 10 pin plug
Dome Supervision use door trigger wire
Trunk/Hatch Release blue/white  -  release switch on dash
Notes: The hatch release motor wire is white (5wi) in the driver kick, gray 13 pin plug, pin 3.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Horn Trigger GREEN/ YELLOW  -  horn switch
iceohio
Member - Posts: 37
Posted: February 21, 2006 at 11:25 PM / IP Logged
Can you try reposting this in a way I can read it? ;-)
Joseph
ohmygodihavenoh
Member - Posts: 7
Posted: February 21, 2006 at 11:33 PM / IP Logged
Sorry, let me try that again.
Today I thought that I would verify the correct wiring before installing my unit.  What I found was that a (-) pulse on the blue/white wire does lock all doors, but a single (-) pulse on the blue / YELLOW wire does nothing.  Two consecutive pulse or double pulse (-) on the blue / YELLOW wire unlocks all the doors.  Can anybody help me out on how to get drivers priority unlock to work.  In the worst case I assume that I can rip off the drivers door panel and wire the 1st unlock wire to the motor with a relay and use the 2nd unlock wire from the unit to drive the blue / YELLOW wire.  Does anyone know an easier way to do this?
Also can anybody tell me from the diagram below what the Green Power Unlock wire does, I cant seem to find it.  Does it exist and does it function the same as the blue/white unlock wire?.   Finally does anyone have an idea what the Lock Motor and Unlock Motor blue and red wires do and what 5wi stands for?
Thanks for all your help everyone.
Dave
12volts  white (25A)/black (15A)  +  ignition harness
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
