2005 Chevy Express Van Door Switch Prob
nexdeci
Member - Posts: 28
Posted: February 27, 2006 at 1:24 PM / IP Logged
Using a Prestige APS997 alarm. I've found all 3 of the door triggers for the vehicle in the BCM. Each wire has it's own diode. For some reason when opening the any of the doors the alarm does not trigger. Perhaps I used the wrong diode?
sparkie
Platinum - Posts: 2,061
Posted: February 27, 2006 at 1:47 PM / IP Logged
The diodes may be backwards. You should install them with the white band on the diode on the side closest to the BCM. Band points towards the BCM.
sparky
nexdeci
Member - Posts: 28
Posted: February 27, 2006 at 9:35 PM / IP Logged
I'll definitely check on that. I'm wondering also if there is a specific diode I should be using.
nexdeci
Member - Posts: 28
Posted: March 04, 2006 at 2:31 PM / IP Logged
Thanks for the info sparkie. Switched the diodes around and the doors are working.
sparkie
Posted: March 05, 2006 at 10:37 AM / IP Logged
You are welcome.
sparky
