Uninstalled Viper 791, car won’t start
jones100001
Member - Posts: 42
Posted: March 22, 2006 at 4:35 PM / IP Logged
I disconnected everything and removed alarm from my car. Can won't crank now. It won't even catch. Any suggestions on what I should check for?
masterk
Member - Posts: 19
Posted: March 22, 2006 at 4:45 PM / IP Logged
your starter circuit is open if alarm had starter kill installed when you removed alarm you must reconnect  starter wires should have went to starter kill relay
8d
crawford7827@bellsouth.net
kgerry
Platinum - Posts: 3,455
Posted: March 22, 2006 at 4:47 PM / IP Logged
thick violet and green wires from the viper primary harness need to be resoldered together....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
jones100001
Member - Posts: 42
Posted: March 22, 2006 at 8:47 PM / IP Logged
you suggesting I just reconnect the starter wires?
dstang24
Copper - Posts: 98
Posted: March 22, 2006 at 10:26 PM / IP Logged
That's exactly what they're saying.  The wires were cut when the alarm was originally installed.
Dstang24
Team Edge Audio
jones100001
Member - Posts: 42
Posted: March 22, 2006 at 10:52 PM / IP Logged
I didn't have access to a soldering gun to solder the starter wires together so I made a jumper cable but still no luck.  Maybe something to do w/ factory alarm?
Ravendarat
Platinum - Posts: 2,806
Posted: March 22, 2006 at 11:18 PM / IP Logged
What kinda vehicle is this and did you originally install the alarm?
jones100001
Member - Posts: 42
Posted: March 23, 2006 at 12:43 AM / IP Logged
2001 Nissan Maxima and I did the install
kgerry
Posted: March 23, 2006 at 8:36 AM / IP Logged
plug in the XCRS relay pack... does the car start now?  then you need to leave it connected or else resolder the starter wire which was spliced in order to facilitate the starter kill option during the original install.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
masterk
Member - Posts: 19
Posted: March 23, 2006 at 8:48 AM / IP Logged
the vechicle has 2 starter wires the main and  cold start the main should be BLACK/ red BLACK/ white the 2nd is BLACK/ blue stripe if the starter does not engage at all the problem is with main starter wire if it turns but does not start i would check 2nd starter wire make sure main starter wire has been reconnected after you remove alarm
8d
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
