remote not working at all
elpaisa
Member - Posts: 7
Posted: April 23, 2006 at 5:24 PM / IP Logged
i am having a problem gettinng my remote to work,  it's not even opening the doors or even making go off the alarm....i change the battery and seems to be fine, but it's not making any communication with the alarm at all.please guys any suggestions...i don't want to go with the customer service of this company they are a pain.by the way the alarm is a absolute abs700. thanks a lot.
Platinum - Posts: 12,488
Posted: April 23, 2006 at 10:36 PM / IP Logged
Did you install the system or was it isntalled by a shop ? First off I would see if the remote control is programmed to the unit. Next is to see if the antenna is plugged in, then check for power at the unit and the fuse & lastly make sure that the rest of your wiring is correct including the ground.
elpaisa
Member - Posts: 7
Posted: April 24, 2006 at 5:12 PM / IP Logged
weel, this alarm has been installed in my car for a couple of years, like six months ago the car was stolen and the alarm stopped working. the shippest way that i though to get an alarm for the car, was buying the same one; and the only thing that i have to do is to swap the alarm module, and thats what i did.. but know i can't get it to work. i tried to reset the alarm by unplugging the (-) side of the battery and it works for a couple of seconds and then it goes bad again.the alarm was first isntalled in a shop but i did change the alarm module.
kohara73
Copper - Posts: 192
Posted: April 25, 2006 at 12:07 PM / IP Logged
Any new alarm module will probably have to be programmed to receive from your remote.
Keith
elpaisa
Member - Posts: 7
Posted: April 25, 2006 at 2:50 PM / IP Logged
the new alarm module came with it's own remotes, but either one of the wants to work.
elpaisa
Member - Posts: 7
Posted: April 25, 2006 at 3:20 PM / IP Logged
elpaisa wrote:
the new alarm module came with it's own remotes, but either one of them wants to work.
kohara73
Copper - Posts: 192
Posted: April 25, 2006 at 10:44 PM / IP Logged
Many new remote start or alarm systems come with remotes that are not programmed to the brain.  This may be the case here.
Keith
Posted: April 26, 2006 at 8:12 AM / IP Logged
What kind of alarm is it ?
elpaisa
Member - Posts: 7
Posted: April 26, 2006 at 2:54 PM / IP Logged
it's an    "absolute abs-700".
