Mazda 626 single wire doorlocks
dnoutlaw
Posted: April 29, 2006 at 1:35 AM / IP Logged
I am installing a K9 Mundial 2 alarm in my 98 Mazda 626. I understand that it has a single wire doorlock system. The doors are unlocked when ground is directly applied to the wire and locked when grounded through a 1k resistor. Is a DLS system necessary for keyless entry? With a negative pulse wire for each, lock and unlock, can I simply install the 1k resistor on the lock wire only? Thanks in advance for any advice.
mo12v
Posted: April 29, 2006 at 8:53 AM / IP Logged
Sometimes you will need the DLS..........
But try hooking the Resitor directly to the Door Lock Plug first.
Also OMEGA makes a DLR-U that has the Relays & Resistors built in.....
MO
