door lock problem 2005 forenza
4xwc24
Member - Posts: 13
Posted: May 07, 2006 at 6:26 PM / IP Logged
 I have a 2005 forenza and my problem is I cannot lock the car with the remote but i can unlock it with the remote . I have hooked all the wires up (the hood pin switch wire ,the accessory wire ,ign wire ,both door lock wires,trunk release,horn wire) everything works except the lock on the remote. i can remote start the car , unlock the car , unlock the trunk, i just can't lock the car. the alarm is a direct tech 927 their tech support said this car does not need relays but when i'm sitting in the car and i press the lock button on the remote and the doors are already locked i can hear the doors trying to lock. does this mean i need relays or do i have the wrong wires very confused appreciate any help i can get        the current wires i'm using for lock is white and the unlock is PURPLE / white
tony stewart
mo12v
Posted: May 07, 2006 at 8:47 PM / IP Logged
I have:
Lock = lt. GREEN / WHITE
Unlock = white or yellow
Disarm = dk. blue or lt. green
All @ Driver Door Harness
MO
4xwc24
Member - Posts: 13
Posted: May 07, 2006 at 10:04 PM / IP Logged
i'm sorry you're right the lock wire i have the alarm attached to is a lt.GREEN / WHITE and the unlock wire is white but do i need a relay because i bought some five pin relays
tony stewart
mo12v
Posted: May 08, 2006 at 7:05 AM / IP Logged
Best way to check is to touch a GROUND wire to Lock or Unlock wire to see if both will work.  If so & your 927 does NOT then you will need 2 Relays.
MO
4xwc24
Member - Posts: 13
Posted: May 08, 2006 at 8:46 PM / IP Logged
how is the best way to hook up the relays do i need to reverse polarity
tony stewart
mo12v
Posted: May 08, 2006 at 9:30 PM / IP Logged
2 SPDT Relays ( Single Pole Double Throw ):
Relay 1
LOCK:
PIN 87 = lt. GREEN / WHITE wire
PIN 87a = XX
PIN 30 = GROUND
PIN 85 = Negative Lock Output from 927
PIN 86 = Constant 12 volt ( + )
Relay 2
UNLOCK:
PIN 87 = white or yellow
PIN 87a = XX
PIN 30 = GROUND
PIN 85 = Negative UNLock Output from 927
MO
4xwc24
Member - Posts: 13
Posted: May 13, 2006 at 9:23 AM / IP Logged
I hooked the relays up just like you said and that caused the car to lock with the remote but not unlock does this mean i need to reverse the polarity or is there some other way to hook up the relays
tony stewart
mo12v
Posted: May 13, 2006 at 2:07 PM / IP Logged
Did you verify the UNLOCK wire in the Vehicle??
Do you have Output from the Relay?
MO
4xwc24
Member - Posts: 13
Posted: May 13, 2006 at 4:11 PM / IP Logged
if you mean grounding the white wire in the car to see if it would unlock then yes
if you mean does the relay make a clicking noise then yes
is that what you mean if so then what can i do now
thanx again for all of your help
tony stewart
mo12v
Posted: May 13, 2006 at 10:05 PM / IP Logged
Relay should make noise and you also should have NEGATIVE Output on PIN 87.
Be sure you are using SPDT Relays ( Single Pole Double Throw )
MO
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
