hornet 563t, 1989 honda civic
elchapin
Member - Posts: 13
Posted: May 08, 2006 at 9:08 AM / IP Logged
I am installing this alarm into an 1989 honda civic 5 speed I had a question on 3 wires from the alarm to what I would connect them to?
first wire = remote start activation ( - )
second wire = igntion input to alarm ( + )
third wire = neutral safety switch inout ( - ) I think since my car is stick I will just ground this but I want to be sure.
Also do I need to add a starter kill to this alarm
erh
dare_ds69
Silver - Posts: 419
Posted: May 08, 2006 at 1:40 PM / IP Logged
first wire = remote start activation ( - )  you don't need it
second wire = igntion input to alarm ( + ) goes to ignition on the car BLACK / YELLOW
third wire = neutral safety switch inout ( - ) I think since my car is stick I will just ground this but I want to be sure. since you car is 5 speed conect it to the e-brake
and yes you have to do a starter kill
hornet 563t, 1989 honda civic -- posted image.
how own your mind, control your life.
MECP certified. always use a DMM
elchapin
Member - Posts: 13
Posted: May 08, 2006 at 4:01 PM / IP Logged
thanks I kind of thought that is what I needed to do but wanted to be sure.
erh
