alarm led placement
realitycheck
Silver - Posts: 751
Posted: May 09, 2006 at 3:46 PM / IP Logged
Hey guys quick question, about placement of the led for your alarms. Where do you guys normally place them in cars?   What the most common factory placements?
mo12v
Posted: May 09, 2006 at 3:49 PM / IP Logged
Usually depends on Vehicle or Installer..........
You would probably want to put it where anyone can see it.
Good detterent is LED & Alarm Stickers
MO
realitycheck
Silver - Posts: 751
Posted: May 09, 2006 at 3:53 PM / IP Logged
yeah i thought about on the a pillar drivers side. Drilling a hole in it and using one of those radio shack led holders. the little black ones. just looking for a really clean install.
xtremej
Gold - Posts: 1,440
Posted: May 09, 2006 at 3:54 PM / IP Logged
Column cover seems to work, have recently put some in tops of door panels though. Done a couple of the scanning leds in dash.  Most common factory spot is the security light gauge cluster, unless its a vw. Some vw's have them right next to the locks on top top of the door panel.
Black Dak
Copper - Posts: 50
Posted: May 12, 2006 at 12:31 AM / IP Logged
I used one of those blue LED bars that scan back and forth, and it's mounted on the dash, at the windshield, drivers dife.  Very visible.
slowfire01
Member - Posts: 16
Posted: May 12, 2006 at 2:08 AM / IP Logged
black: the cheap things that are led involved will get your car broken into because the theifs see them in the cheap auto parts store, granted if you have an alarm he will probley leave but thats a good start to his day to see the cheap stuff because people that spend hundreds of dollars on a alarm don't cut the led that comes with it and buy a 10 dollar gaudy led. mine is on the forefront trim of the dash in the center of the dash, and a tip is to use female and male disconnects in case you have to take the dash apart as i did to glass it and other things.
jason
mecp certified installer
intersts provoke installs
slowfire01
Member - Posts: 16
jason
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
