Crime Guard 328i Problem
nhcivicguy
Posted: May 19, 2006 at 9:01 AM / IP Logged
My Crime Guard 328i alarm system is not functioning properly. The siren is not funtioning. The lock/unlock feature of the alarm still works properly. Even if I purposely set off the alarm, the audio part of the alarm doesn't work. It does deactivate the ignition and the rest of the alarm functions. Does anyone have any troubleshooting suggestions?
xtremej
Gold - Posts: 1,440
Posted: May 19, 2006 at 9:14 AM / IP Logged
Do the lights flash when you set off the alarm? If yes then the only thing not working is the siren?
nhcivicguy
Posted: May 19, 2006 at 2:10 PM / IP Logged
The lights do flash when the alarm goes off... The siren is now making a little bit of noise, but is not healthy. Is there a way to buy a new siren?
nhcivicguy
Posted: May 19, 2006 at 2:22 PM / IP Logged
Now the siren is completely dead again...
xtremej
Gold - Posts: 1,440
Posted: May 19, 2006 at 2:24 PM / IP Logged
You can purchase a siren seperate. I would find your local stereo shop I am sure they can help you out. Price wise they aren't to exspensive.
Hornshockey
Silver - Posts: 520
Posted: May 19, 2006 at 2:25 PM / IP Logged
any 2 wire, 12 volt siren will work.  Before you replace it, I would check where the siren is gounded, the ground may have come loose, this would cause no sound or a very weak sound.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
nhcivicguy
Posted: May 19, 2006 at 8:19 PM / IP Logged
How can I check if the siren is grounded? Currently, it has four (maybe five) wires running into it... They all appear tight... The siren itself is loose in the engine compartment.
