457G module
untame350
Member - Posts: 10
Posted: June 06, 2006 at 8:27 AM / IP Logged
im about to do a  2005 tahoe and i've never heard of this module needed (457G). can i just use  a DLS module! Also am i to take the rear quter panel out to find the door locks. Also can i use the dome light for door triggers to avoid going to each door with diodes.
xtremej
Gold - Posts: 1,440
Posted: June 06, 2006 at 8:45 AM / IP Logged
are you installing a remote starter or alarm or both?
untame350
Member - Posts: 10
Posted: June 06, 2006 at 9:18 AM / IP Logged
sorry, both! alarm with remote sarter
djfearny2
Silver - Posts: 810
Posted: June 06, 2006 at 9:26 AM / IP Logged
the 457g is the module for the databus door locking system as well as factory arm disarm. a module such as the 555l will be needed for the passlock chipped key security system.
Jon
Installer/Help Technician
---coral springs florida---
xtremej
Gold - Posts: 1,440
Posted: June 06, 2006 at 9:36 AM / IP Logged
If you use a 457gw it will do ignition bypass, door locks, factory disarm/arm and on certain makes/models heated seats,rear defrosters.....
untame350
Member - Posts: 10
Posted: June 06, 2006 at 9:54 AM / IP Logged
thanks a mill
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
