2007 escalade alarm/ remote start wiring
soundblazers
Posted: June 23, 2006 at 1:48 PM / IP Logged
starter wire with 1300 ohm resistor @ BCM White pin # 4 grn plug
12v behind fuse box RED / blk
ignition pink @ bcm pin 14 grn plg
accessory brown @ bcm pin 21 grn plug
power lock / unlock ALL doors @ drivers door module
take apart module @ molex plug in module need to drill hole and run lock/unlock wires with negative trigger. test with multimeter soldering required. brn plug
parking lights (-) @ switch lt.blue
door triggers (-) diode isolate all
drivers door: at module in door grey with black
passenger door: at module in door blk/wht
driver rear door: blue/blk @ bcm pin 15 pink plug
passenger rear door: GREEN/ blk @ bcm pin 14 pink plug
hatch pin pnk/blk pin 12 pink plug
glass release pink pin 24 pink plug
auto gate open/ close GREEN/ wht @ switch on roof
factory alarm disarm lt.green @ door module REQUIRED
brake wire lt.blue/ white @ bcm pin 6 brown plug
key sense is not required for remote start!!!!
USE tach signal for remote start purple wire drivers side forward most coil.
Took me 13 hrs to get this alarm done hope it helps!
Sound blazers Coral Springs, FL
soundblazers
Posted: June 23, 2006 at 2:05 PM / IP Logged
oh also need 556u if key has + sign on it.
I tried alternate wiring for keysense as per DEI tech but, still did not work. remote started on accident with out anything connected to keysense and worked perfectly since then.
as well 5 wire on the door locks did not work. as the door locks do not rest @ ground.
FYI if you open the door lock module I I described befor do no use the - lt blue / + white wires for the rear door locks at the same time it will cause the alarm to feedback and the door locks will start going crazy when you shut the car off.
One other note I did not hook up starter kill. even after cutting the starter wire ( white wire ) the truck would still start properly. looking for work around.
mkainp
Posted: August 10, 2006 at 4:40 PM / IP Logged
did you complete the remote start portion of the alarm system. i got everything working except the remote start. this 07 comes with factory installed remote start. any tips on adding remote start.
black cavy
Copper - Posts: 78
Posted: August 10, 2006 at 7:04 PM / IP Logged
I have 3 questions
1.starter wire with 1300 ohm resistor @ BCM White pin # 4 grn plug
12v behind fuse box RED / blk.
So the starter wire from the new Combo unit witch is going there also needs a 1300 ohm resister .
Got alittle confused what your trying to say
2.12v behind fuse box RED / blk
So you take the fuse panel out to get the 12v wires or can you go somewhere else
3power lock / unlock ALL doors @ drivers door module
Could you just use a interface for this or is this like the old school way
I know i will never work on one but i was wondering about those cuple things,the only Escalade i've sat in was a 2002 at the dealer ship.
josh1979
Silver - Posts: 320
Posted: August 10, 2006 at 11:28 PM / IP Logged
2007 escalade alarm/ remote start wiring -- posted image.
bring back the rotary phone so i dont have to press 1 to proceed in english
josh1979
Silver - Posts: 320
Posted: August 10, 2006 at 11:34 PM / IP Logged
12volts
RED / white (2A)
ign harness
Notes: For high current 12V, use RED / black (60A) and RED / black (60A) at the fuse box, black 40 pin plug, pins F1 and E3, or go to the battery.
Starterwhite + ign harn or BCM, lt. grn plug, pin 4
Notes: Starter is positive trigger thru a 1300 ohm resistor.
The BCM (Body Control Module) is to the left of the steering column.
See DirectFax document 1605 for remote start interface information.
Second StarterN/A
Ignitionpink + ign harn or BCM, lt. grn plg, pin 14
Notes: The BCM (Body Control Module) is to the left of the steering column.
Second IgnitionN/A
Third IgnitionN/A
Accessorybrown + ign harn or BCM, lt. grn plg, pin 21
Second AccessoryN/A
Keysensepink + ign harn or BCM, lt. grn plug, pin 2
Power Locksee DirectFax document 1607
Notes: To lock/unlock the driver door go to the driver door module or motor in the door and 5wi the tan (lock) and purple (unlock) motor wires.
To lock/unlock the passenger door go to the passenger door module or motor in the door and 5wi the tan (lock) and gray/black (unlock) motor wires.
To lock/unlock the rear doors use lt. blue (+) and white (-) at the BCM, gray plug, pins 7 and 9.
Power Unlocksee power lock notes
Lock Motorgray 5wifuse box, black 14 pin plug, pin B4
Unlock Motorpurple 5wiDDM, brown 16 pin plug, pin 8
Notes: The DDM (Driver Door Module) is in the driver door.
Parking Lights+brown (L), brown (R) + underhood fuse box, blk 30 pin plug
Parking Lights-lt. blue - switch or BCM, natural plug, pin 8
Hazardswhite - switch or BCM, lt. grn plug, pin 19
Turn Signal(L)lt. blue/wht (F), yel/blk (R) + BCM, brown plug, pins 4 and 1
Turn Signal(R)dk blu/wht (F), dk grn/wht (R) + BCM, blk plg, pin 5; brn plg, pin 2
Reverse Lightdk. blue + BCM, natural plug, pin 22
Door Triggersee notes - see notes
Notes: The LF door is gray/black at the DDM, brown 16 pin plug, pin 13. The RF door is BLACK/ white at the PDM, brown 16 pin plug, pin 13. The LR door is lt. blue/black at the BCM, pink plug, pin 15. The RR door is lt. GREEN/ black at the BCM, pink plug, pin 14. Use all four wires and diode isolate each.
The PDM (Passenger Door Module) is in the passenger door.
Dome Supervisiongray + BCM, natural plug, pin 5
Trunk/Hatch Pinpink/black - BCM, pink plug, pin 12
Hood Pinpink/black - pin sw or BCM, black plug, pin 17
Trunk/Hatch Releasepink (glass), gray (gate) - BCM, pink plug, pins 24 and 13
Notes: Meter these wires while opening the liftglass or liftgate from the handle on the rear liftgate.
On vehicles with the power liftgate, use dk. GREEN / WHITE (-) at the switch in the overhead console.
Power Sliding DoorN/A
Factory Alarm Arm
Factory Alarm Disarmlt. green - DDM, brown 16 pin plug, pin 4
Notes: Meter this wire while turning the key in the driver door key cylinder.
Disarm No Unlockwith ignition and Passkey
TachometerNOT pink, brown, or black ac any ignition coil or fuel injector
Wait to startN/A
Brake Wirelt. blue/white + switch or BCM, brown plug, pin 6
Notes: Meter this wire while pressing the brake pedal with the ignition on.
Parking Brakelt. blue - switch or BCM, brown plug, pin 16
Horn Triggertan - switch or BCM, brown plug, pin 18
Memory Seat 1orange + switch or DDM, blk 26 pin plg, pin 5
Notes: Memory seat 1 is positive trigger thru a 2260 ohm resistor. Memory seat 2 is positive trigger thru a 4260 ohm resistor.
Memory Seat 2same as memory seat 1 wire +
Memory Seat 3N/A +
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III+
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays:Relay Type:
Starter Relay
Engine compartment fusebox, Driver side
Part #: 6404A
autoshield
Posted: August 21, 2006 at 10:37 AM / IP Logged
 does the tech tip from dei  for the tahoe work on an 07 escalade ?
xtremej
Gold - Posts: 1,440
Posted: August 21, 2006 at 11:59 AM / IP Logged
Yes, should be the same wiring.
black cavy
Copper - Posts: 78
Posted: August 23, 2006 at 8:36 AM / IP Logged
IM going to to look into this somemore
Hymer
Silver - Posts: 695
Posted: August 23, 2006 at 4:38 PM / IP Logged
I just did a 06 lucern that sound somewhat simaler to this .. Bypass kit XK06 fimware pkg9 this does the 1300 ohm starter resistance and hybrid pasllock .. www,xpressdownload.com the next is the XK01 palatform gmdl6 firmware , this will take care of the locks disarm hatch release ect... The rem start on tthis lucern gave me a lot of crap yesterday but both of these units worked great and it would have made the install a ton easier (time wise) all the manuals are downloadable from the site also!
Good Luck
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Thursday, October 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
