hornet 564t and 2004 toyota sequoia
clock97
Member - Posts: 11
Posted: July 04, 2006 at 11:08 AM / IP Logged
i have installed this alarm before with the remote start on my cavalier but i did some searching and it looks to be a little harder with the sequoia. do you need the bypass from bypasskit.com "TBKIV" to make the remote start work or is there another way?
captainzab
Silver - Posts: 606
Posted: July 04, 2006 at 9:52 PM / IP Logged
the 2004 sequoia does need a bypass, but the TBKIV requires you to give up a key. If you know there isn't a bypass kit that doesnt require you to give up a key to use, then purchase the TBKIV and throw in a key.
FYI, its the same thing as the 556U by directed or the 791 by bulldog.
I recommend getting whichever is cheapest because its gonna cost you to get a new key to replace the one you have to place in the bypass
clock97
Member - Posts: 11
Posted: July 05, 2006 at 9:57 AM / IP Logged
thanks for the info, do i need a relay for the factory disarm or is it okay without one?
captainzab
Silver - Posts: 606
Posted: July 05, 2006 at 12:57 PM / IP Logged
no relay needed, just connect factory disarm wire to the vehichle
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
