viper 791xv activation wire?
bigfoot286
Copper - Posts: 53
Posted: July 10, 2006 at 9:24 PM / IP Logged
one question about it the H1/3 WHITE/ Blue remote start (-) activation wire. what exactly do the mean by it needs two negitive pulses? two just once or every time it goes to start? and would nutrule safty swich work for that? it is the only thing thta confuses me about the alarm everthing else i got. and if it helps its an 05 dodge stratus coupe
JWorm
Platinum - Posts: 2,208
Posted: July 10, 2006 at 9:51 PM / IP Logged
Its not needed. Leave it alone.
bigfoot286
Copper - Posts: 53
Posted: July 10, 2006 at 10:26 PM / IP Logged
thats what i thought. but what would i do with it if i were to use it?
captainzab
Silver - Posts: 606
Posted: July 11, 2006 at 3:17 PM / IP Logged
you would use it if you had another alarm system that had a aux channel. By sending 2 consecutive pulse to this wire (from your alarm system with the aux channel) it will remote start
But since you have an alarm (791), no need
Learn something new everyday!
extreme1
Silver - Posts: 1,070
Posted: July 11, 2006 at 5:27 PM / IP Logged
if you had a DEI timer/temp module you would use the WHITE/ blue input.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
