A/M alarm
abchase
Posted: July 28, 2006 at 1:08 PM / IP Logged
Ok, one of the guy's I work with, just bought a used truck. The truck has a CM2400, already installed. We've determined that it's either a CompuStar CM2400, or a First Tech, or maby even a Vision. I belive all three are related. It was installed into a 2003 Dodge Ram 2500 HD. We've got the unit to go into learning mode, but I cant seem to get it to respond to the remote I have. (a CompuStar s/n:004801, FCC ID: 044JR1600)
If there is anyone that could help it would be greatly appreciated....
abchase
Posted: July 28, 2006 at 2:22 PM / IP Logged
Ok my mistake it's a CM4200.
Not a Cm2400... Sorry
abchase
Posted: July 31, 2006 at 8:23 AM / IP Logged
BUMP!
Noone... A/M alarm -- posted image.
Moderator - Posts: 12,488
Posted: July 31, 2006 at 8:56 AM / IP Logged
You must toggle the ignition switch 5 times within 3 seconds and press the lock button as well within this time frame. If you toggle the switch 5 times and you do not get 2 light flash response, then you did not toggle the switch fast enough.
abchase
Posted: August 02, 2006 at 3:09 PM / IP Logged
Thank you for the responce. I've gotten' it into the programing mode. I just can't seem to program the reomte. But for an update, I did find out that....   The remote we got to replace the "missing ones" is AM, where as the remote we need is FM. I'll update when the new ones arrive.
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
