alarm wont lock doors
playboy00786
Member - Posts: 33
Posted: August 06, 2006 at 11:19 AM / IP Logged
I have a 99 chrysler lhs and a scytek 5100rs alarm everything works except for the lock button. it will unlock but wont lock. When i hit the lock button it will arm the system but wont lock the doors. Any help thanks.
captainzab
Silver - Posts: 606
Posted: August 06, 2006 at 11:58 AM / IP Logged
Lock wire not hooked up, wrong resistance, or relay messed up.
99 Chrysler LHS
Lock Wire Diagram
the DOOR LOCKS on this vehicle require a (+)Positive thru a 2700 Ohm resistor to LOCK and a (+)Positive thru a 620 Ohm resistor to UNLOCK, some units will also require 2extra relays for the keyless entry feature to work properly
Note: You Always Dont Get What You Pay For.
Saturday, February 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
