What is the best keyless entry under $100
gametom
Posted: August 27, 2006 at 11:05 AM / IP Logged
Hi i have a 91 toyota 4runner with power door lock it also has a python 1000 code plus in it but i have no idea if it is connected proporly and i have no remotes for it so i whould like to add a keyless entry system i was just wondering if there is a brand model store that i should use i'm looking to spend less then $100USD
Thank you
Tom
jesselyons2002
Member - Posts: 41
Posted: August 28, 2006 at 12:20 AM / IP Logged
You can just go pick one up at pepboys or autozone. I just put a Audiovox AA-925 in 91 Honda Accord and it works good.
I Love my Crimestoppers
KarTuneMan
Platinum - Posts: 7,056
Posted: August 28, 2006 at 11:33 AM / IP Logged
CS-865.RKE.II
Remote Keyless Entry System
What is the best keyless entry under $100 -- posted image.
  • 2 Four-Button Remote Transmitters
  • On-Board Flashing Light Relay with + or - Jumper Setting
  • Now with Three Auxiliary Remote Outputs for Power Trunk Release, Add-On Remote Start or Power Window Control Modules
  • Negative Armed Output
  • Dedicated Remote Panic
  • Programmable Auto Lock / Unlock with Ignition
  • On-Board Relays for Door Locks
  • On-Board Dome Light Relay with + or - Jumper Setting
  • Optional Separate Driver's Priority and Passenger Door Unlock Output
  • Horn Output for Lock / Unlock with Ignition
  • Programmable Double Unlock Pulse
  • Programmable Longer Horn Pulse for Dodge / Chrysler Caravans
Lot's less that 100 bucks...and look at ALL those features!!!
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
