lock unlock with ignition? no alarm
rallysport
Copper - Posts: 172
Posted: September 09, 2006 at 6:21 PM / IP Logged
i have a 06 ford freestar cargo work van, it has factory keyless entry but does not lock when i turn the igntion is turned on nor does it unlock when i turn off the ignition. is it possible to wires something up so that it will do this without buying an aftermarket alarm?
mobilecustoms
Silver - Posts: 397
Posted: September 09, 2006 at 10:01 PM / IP Logged
look in the owners manual it should tell there. i know the exploer for 06 has the option for the two.
cooooldman
Posted: September 10, 2006 at 12:21 AM / IP Logged
The 06 Freestar is a simple - type lock system you can do what your wanting to do with a couple of bosh realy's wired to the ing switch. but to me it would be worth the few extra bux to go on and put a keyless entry unit and have the full advantage.
oldschool in ky.
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
