2007 toyota yaris r/s alarm
jmacf14
Copper - Posts: 160
Posted: October 28, 2006 at 6:49 PM / IP Logged
Hi. I need the wiring info on a 2007 toy yaris. If anyone can post for me I would appreciate it. Tnx
jmacf14
Twelvoltz
Platinum - Posts: 2,384
Posted: October 29, 2006 at 6:44 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / YARIS / 2007 / Remote Start
[PRINT THIS PAGE]
12volts      yellow (25A), gray (15A)       +       ignition harness
Starter      black (x2)(common)       +       ignition harness
Second Starter      N/A
Ignition      pink       +       ignition harness
Second Ignition      green       +       ignition harness
Third Ignition      N/A
Accessory      white       +       ignition harness
Second Accessory      N/A
Keysense      yellow       -       ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Power Lock      brown       -       driver kick, 20 pin plug, pin 7
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock      yellow to green (double pulse)      -       driver kick, 20 pin plug, pin 8
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is green (-) at the fuse box, middle, 18 pin plug, pin 15.
Lock Motor      white to orange       5wi      driver kick, 20 pin plug, pin 10
Unlock Motor      lt. blue to pink       5wi      driver kick, 20 pin plug, pin 20
Parking Lights+      green       +       fuse box, top L, 30 pin plug, pin 29
Parking Lights-      white       -       headlight switch
Notes: Not available on all models.
Hazards      black       -       hazard light switch
Turn Signal(L)      lt. green       +       fuse box, top L, 30 pin plug, pin 27
Turn Signal(R)      yellow       +       fuse box, top L, 30 pin plug, pin 28
Reverse Light      red       +       fuse box, top L, 30 pin plug, pin 30
Door Trigger      see notes       -       fuse box, top left, 30 pin plug
Notes: The LF door is red in pin 21. The RF door is blue in pin 24. The LR door is green or yellow in pin 5. The RR door is blue in pin 20. The rear doors are common on some models. Use all four wires and diode isolate each.
Dome Supervision      pink       -       fuse box, L side, 6 pin plug, pin 2
Trunk/Hatch Pin      lt. blue       -       fuse box, top L, 30 pin plug, pin 7
Hood Pin      white       -       pin sw or theft warning ECU, pin 4
Notes: The theft warning ECU is behind the glovebox.
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      disarms with unlock
Disarm No Unlock      use key sense wire
Tachometer      lt. green       ac       data link conn. under dash, pin 9
Wait to start      N/A
Brake Wire      green to purple       +       fuse box, top L, 30 pin plug, pin 12
Parking Brake      yellow       -       fuse box, top R, 16 pin plug, pin 2
Horn Trigger      black to lt. green       -       fuse box, top, 36 pin plug, pin 28
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Optional on the sedans and S sedans, not standard equipment.
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
jmacf14
Copper - Posts: 160
Posted: October 29, 2006 at 1:49 PM / IP Logged
thanks for the info. just what i needed.
jmacf14
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
