07 mazda cx-7 alarm/radio
Z-man
Member - Posts: 12
Posted: November 09, 2006 at 12:00 AM / IP Logged
Just seeing if anyones got these diagrams yet( alarm/radio) and if so, could I please get any info for this veh. Thanks
Mike M2
Platinum - Posts: 2,652
Posted: November 09, 2006 at 6:54 AM / IP Logged
12volts red (40A), red (40A)  +  ignition harness
Starter gray/red  +  ignition harness
Second Starter N/A
Ignition GREEN/ YELLOW  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory pink / YELLOW  +  ignition harness
Second Accessory yellow  +  ignition harness
Keysense RED / black or BROWN / green  +  ign harn or BCM, 24 pin plug, pin 3C
Notes: The BCM (Body Control Module) is high in the driver kick.
Power Lock GREEN/ red to BLACK/ blue  -  dr kick or BCM, 30 pin plug, pin 5M
Notes: Lock is negative trigger thru a 1000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock same as power lock wire
Lock Motor yellow/black  5wi dr kick or BCM, 6 pin plug, pin 6E
Unlock Motor WHITE/ red to WHITE/ black  5wi dr kick or BCM, 6 pin plug, pin 6C
Parking Lights+ RED / blue  +  driver kick, harness to rear
Parking Lights- BLACK/ red  -  headlight switch, pin L
Hazards BLACK/ orange  -  switch or BCM, 24 pin plug, pin 3J
Turn Signal(L) blue  +  dr kick or BCM, 30 pin plug, pin 5R
Turn Signal(R) blue/red  +  dr kick or BCM, 30 pin plug, pin 5O
Reverse Light GREEN/ orange  +  driver kick, harness to rear
Door Trigger see notes  -  BCM, 30 pin plug
Notes: The LF door is BLACK / YELLOW in pin 5Y. The RF door is BLACK/ blue in pin 5V. The LR door is BLACK/ orange in pin 5S. The RR door is BLACK/ green in pin 5T. Use all four wires and diode isolate each.
Dome Supervision BLACK/ blue  -  dr kick or BCM, 6 pin plug, pin 6B
Trunk/Hatch Pin BLACK/ red  -  dr kick or BCM, 30 pin plug, pin 5P
Hood Pin BLACK / YELLOW  -  pin sw or BCM, 16 pin plug, pin 1A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm BLACK/ white  -  dr kick or BCM, 30 pin plug, pin 5A
Notes: Meter this wire while turning the key in the driver door key cylinder.
Arm is negative trigger thru a 1000 ohm resistor. Disarm is a straight negative trigger. MUST use relays.
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock
Tachometer GREEN/ stripe  ac  any fuel injector
Notes: Can also go to any ignition coil and use the wire that is NOT green or BLACK/ blue.
Wait to start N/A
Brake Wire RED / white  +  brake pedal switch or driver kick
Parking Brake BLACK/ red  -  switch or BCM, 16 pin plug, pin 1C
Horn Trigger black  -  switch or BCM, 24 pin plug, pin 3H
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
07 mazda cx-7 alarm/radio -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Mike M2
Tech Manager
CS Dealer Services
Z-man
Member - Posts: 12
Posted: November 09, 2006 at 9:05 AM / IP Logged
Thanks mr. Mike..I'll check it out. 07 mazda cx-7 alarm/radio -- posted image.
Z-man
Member - Posts: 12
Posted: November 29, 2006 at 8:38 PM / IP Logged
will the 556U work for this install on the remote start. Thanks for any info you might have!
jasondavis05
Copper - Posts: 55
Posted: December 05, 2006 at 12:42 AM / IP Logged
Yes Mike M2 has it there at the bottom
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
