Odyssey Door Trigger
daxton
Member - Posts: 14
Posted: November 18, 2006 at 11:32 AM / IP Logged
I did an install on my prelude a few years back, and the DEI alarm simply hooked up the 2 door lock/unlock wires directly to the prelude, and all worked fine (i believe both prelude wires were (-) pulse). With the odyssey 2004, both show (-) pulse.. do i just connect the wires directly as i did in the prelude? Also, do the dei systems still allow direct connection, or do relays have to be used now? i think my old system was a Viper 500HF, and allowed direct connection..
thanks!
dax.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 18, 2006 at 12:45 PM / IP Logged
I would use the outputs from your unit to trigger relays....be safe that way.
Some of the guys here on the 12volt will tell you otherwise, but I like to do it strong and proper.
JWorm
Platinum - Posts: 2,208
Posted: November 18, 2006 at 5:00 PM / IP Logged
The wires you tap into to lock/unlock the vehicle are wires that trigger relays. Adding another set of relays is pointless. You just end up with a relay triggering another relay.
To the original poster. you can connect the wires directly. No relays needed.
daxton
Member - Posts: 14
Posted: November 18, 2006 at 5:52 PM / IP Logged
thanks guys... i kinda thought they would still have it the same... on a couple models of dei, it specifically states when you require a relay on the wire (such as second output and so on)
dax.
CruisinS&S
Copper - Posts: 225
Posted: November 18, 2006 at 6:14 PM / IP Logged
Jworm is 100% correct, another set of relays makes no sense. One part of the problem with this site is that there are people who dont know all there is to know about Alarm, r/s giving out advice.
Cruisin Security And Sounds
KarTuneMan
Posted: November 18, 2006 at 9:41 PM / IP Logged
Well ok then......I can only assume your pointing your little finger at me.....Geeee, sorry about all the miss-information I provide.
