Bypassing factory alarm on 2000 durango
tct0073
Posted: November 28, 2006 at 11:16 PM / IP Logged
I have installed a remote start and alarm on my friends durango but  I can't figuer out how to bypass the factory alarm. Can anyone help me on this? A wiring diagram would be great!
Mike M2
Platinum - Posts: 2,652
Posted: November 29, 2006 at 6:43 AM / IP Logged
Power Lock lt. GREEN/ orange  -  DKP, blk plug, right of park brake
Notes: Lock/arm is negative trigger thru a 647 ohm resistor. Unlock/disarm is negative trigger thru a 1562 ohm resistor. MUST use relays. Unlock requires a double pulse.
Can also use Directed 456L interface module.
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Mike M2
Tech Manager
CS Dealer Services
tct0073
Posted: November 29, 2006 at 7:32 PM / IP Logged
How do you wire up the relays?
