How to arm alarm with engine running
2ndlife
Member - Posts: 15
Posted: December 06, 2006 at 11:01 PM / IP Logged
hi everyone. I am just an amateur with car alarms and I have the following question. How can I hook up the alarm in order for it to be able to arm while the engine is running? I am trying to use a separate turbo timer and I would like to arm the alarm when I leave the car and the timer  my counting down.  Btw my alarm is a healthy 10 + year old Viper 300. It's got the regular hookup w/ starter kill relay.
Thanks in advance if anyone can explain what to do.
2ndlife
Member - Posts: 15
Posted: December 07, 2006 at 1:34 PM / IP Logged
can anyone help?? i 've seen another car with the same alarm being able to arm when driving. I know it can be done but just don't know what connections to change.
Paketa1
Member - Posts: 19
Posted: December 07, 2006 at 1:50 PM / IP Logged
why do u you need the alarm to go of while driving!
if you are trying to make noise on the street try holding panic button while driving.
2ndlife
Member - Posts: 15
Posted: December 07, 2006 at 1:55 PM / IP Logged
I am not trying to make any noise. I just want to be able to arm the alarm when my turbo timer is counting down and engine is running. This way I can get out of the car and arm the car while engine is still running under the turbo timer countdown.
Paketa1
Member - Posts: 19
Posted: December 07, 2006 at 2:47 PM / IP Logged
the alarm system uses the ignition wire for that when the ignition is on it wont arm. you would have to use a swith on that wire. u cant disconect it completly because its needed for programing or passive door locks.
try disconecting the wire and using the alarm while car the car is on.
azn_fcuk
Copper - Posts: 104
Posted: December 07, 2006 at 3:27 PM / IP Logged
you may run into issues with your shock sensor as the car is running. Vibration may set off your alarm. Are there any extra out puts on the alarm you could use to build a relay to disable the sensor.
splaudio
Copper - Posts: 237
Posted: December 07, 2006 at 4:42 PM / IP Logged
i know the ultra alarms you cant have run then arm it because the ignition wire will shut it off. with a remote start and alarm you can have it arm while running...
2ndlife
Member - Posts: 15
Posted: December 07, 2006 at 11:02 PM / IP Logged
I will try taking off the ignition wire to see happens. and i do have extra outputs from the alarm although i dont think the vibration from the car will set the alarm off. if it does, i will turn the sensor sensitivity down.
KPierson
Platinum - Posts: 3,527
Posted: December 08, 2006 at 1:28 PM / IP Logged
Set it up for passive arming.  When the turbo timer shuts the car off it will lock and arm itself.
Kevin Pierson
splaudio
Copper - Posts: 237
Posted: December 08, 2006 at 4:15 PM / IP Logged
i know the starter/alarm units shut the shock sensor off when u remote start...
