Prestige APS996....
deadlysyns
Member - Posts: 6
Posted: January 28, 2003 at 2:28 PM / IP Logged
Anyone familiar with the Prestige APS996 model?
The alarm LED is on constantly which indicates that it is in "Valet" mode.  When I arm/disarm the alarm, the doors lock/unlock and parking lights blink but the siren does not beep.
My question is how do I get out of the "valet" mode?  I still need to teach the alarm the tach wire for remote start.  The manual tells you how to get into "valet" mode but it does not say how to get out of it.
-Thanks
Chris Luongo
Platinum - Posts: 3,746
Posted: January 28, 2003 at 5:11 PM / IP Logged
I can't believe the manual doesn't tell you how to get out of valet.
Turn the key to Run, then tap the valet/program switch once, and the light will go out.
re2gie99
Member - Posts: 7
Posted: March 17, 2003 at 7:38 AM / IP Logged
I have the same alarm, and I'm going to install it this week when I get a chance, I was just wondering, where did you place your antenna inside the car?
rocksound
Member - Posts: 7
Posted: March 17, 2003 at 4:26 PM / IP Logged
for maximum range mount antenna vertical along w/shield post
shawoo
Member - Posts: 19
Posted: March 17, 2003 at 8:43 PM / IP Logged
Its in the book...step #8 or so i beleive...but its tricky to get to the steps, after u hit the button 3 times, turen the ignition back on, then lets say u nee to get to step #8, u hit the button 7 times. Took a few hours and a call to Audiovox to figure this one out.
Jazz3D1
Member - Posts: 8
Posted: March 17, 2003 at 8:47 PM / IP Logged
I have installed about 5 APS 996 in the past 3 weeks.  The alarm is very picky when it comes to programming for some reason and their tech. support is awful.
Have you solved your problem?
re2gie99
Member - Posts: 7
Posted: March 17, 2003 at 10:07 PM / IP Logged
Also, when you're programming the transmitters, what channel is the remote start automatically set to, channel 3 or channel 4?? Are there any other headaches that you guys had when installing these systems that I should know about before I start? (by the way, its going in a 93 Honda Accord)
mxxmikexx
Silver - Posts: 796
Posted: March 18, 2003 at 12:22 PM / IP Logged
as someone already posted, they are real picky when it comes to programming, ive installed alot of the 996's, 785's and 685's, they are good units and i like installing them, alot better than DEI pieces, the installs usually go in alot cleaner, however when it comes to programming, they can be a pain in the as# sometimes, but all in all it could be worse i guess.
