06 bmw z-4 locks
txaggiemp
Member - Posts: 8
Posted: December 19, 2006 at 4:22 PM / IP Logged
anybody install keyless on a 06 z-4? we have the remote start working but no-go on the locks. i have the directech sheet but that hasen't helped at all. i'm looking for first hand knowledge here, i've been through it with directed and they are no help.
the customer is not always right
KarTuneMan
Platinum - Posts: 7,056
Posted: December 20, 2006 at 12:27 AM / IP Logged
LOCK Blue/red At General module behind glovebox   -
 In center plug
 UNLOCK White At General module behind glovebox   -
 In center plug
How could this be difficult? Is the module NOT there? Can you not find the wires this color? Do they NOT test properly?
jihadmatar
Member - Posts: 8
Posted: February 17, 2007 at 2:00 PM / IP Logged
hello, this is jay and i install alarms and starters(basic mecp).
u seem that you know your stuff. i am working on a 1999 a4 2.8 quattro.
have a problem w door locks parts. i am installing the xs- 900s systems. according to its wiring diagarm i need to cut the main wire that is going form the vacuum pump in the trunk to the door switch. this wire should show 12v with door unlocked and 0 when locked. do you know what color or location? or am i wrong all together. any help is greatly appreciated.
email address is jihadmatar@yahoo.com
thanks.
Posted: February 20, 2007 at 4:57 PM / IP Logged
NO NO NO  Check plugs in driver or passenger footwell look for plug on looms coming out of dor into plug, its low current neg for lock and unlock and hold the lockwiire for window close. THAT SIMPLE!06 bmw z-4 locks -- posted image.
jihadmatar
Member - Posts: 8
Posted: February 20, 2007 at 5:09 PM / IP Logged
howie ii,
thanks for the help. what did you mean at the end though by: hold the lock wire for window close. what does this means.
thanks again,
jay.
Posted: February 21, 2007 at 3:47 AM / IP Logged
Use a timed (about 5 secs) neg output and join to lock wire, see installation manual for that alarm.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
