2007 Dodge Ram 1500 Quad Cab starter wire
Tloodis
Posted: December 29, 2006 at 3:35 PM / IP Logged
I'm installing a python 991xp in this truck and have everything working except for the starter kill and remote start due to the fact that I can't find the primary starter wire (supposed to be GREEN/ YELLOW from 06 model)!!! I've tested every wire in the ignition harness with no luck. I found the 2nd starter (PURPLE / brown) but don't know if I use the one on the sentry ring harness or the harness under the turn signal. Any help is appreciated. Thanks in advance.
Hymer
Silver - Posts: 695
Posted: December 29, 2006 at 3:43 PM / IP Logged
There isn't one! Its all muxed into the 2nd start and accy wire.. what bypass are you useing?
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Tloodis
Posted: December 29, 2006 at 3:52 PM / IP Logged
Just used a 556uw. can't figure out how to get the starter kill and accessory to work. I wired it up using the dei 1084 diagram with the -accessory/starter wire. can I use this and the starter kill? Thanks for the quick response.
Hymer
Silver - Posts: 695
Posted: December 29, 2006 at 4:04 PM / IP Logged
Sorry but Im not framiliar with dei's newer stuff.. I use a xk532 or chdl7pk 2 for these new dodges, I'm sure someone will chime in! with the new bypasses ya don't need to worry about starter kill and second accy stuff...
